CUCM DRS Scheduled Backup fails to back up UCM
chrstncline
I am having an issue using the Scheduled Backup for CUCM. When performed manually, the backup will back up both UCM and CDR_CAR. However, when scheduled the backup will show an ERROR result; CDR_CAR is in Features Backed Up but UCM is in Failed Features. Checking the SFTP path verifies this is in fact the case.
I am using OpenSSH on the clientside, running on a Windows box. From reading through many other posts here I understand the issue tends to lie on the client SSH side, but have tried a few different solutions and always wind up with manual backups working fine and scheduled ones (using the same credentials and all) failing or erroring like this. Any ideas?
The CUCM DRS requires a SCP/SFTP server not a client. Where does the backup stop?
Can you please upload a screenshot of what you are observing?
Thanks a lot
Carlo
Please rate all helpful posts "The more you help the more you learn"
