CUCM External Call Contral
bo liu
Level 4
Level 4
hello everyone
i need help about the CUCM ECC
i look up some document,and i know when the call use the interface
the CUCM will send an XACML call routing request to the web service.
But i want to know the format is who defined.
i am not a developer....so i known this question is very stupid.
in my case
the developer give me a url , i config it to the ECCP,but when i use this interface ,i can't see any http package use wireshark only tcp.
i want to known this format is CUCM default or need this URL define???
thanks
You need to configure the options as per the feature guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_011010.html
There shouldn't be any need of specifying the format of the request. CUCM should do it automatically.
-Atul
Atul Gaba
I'm not sure what exactly you are looking for. Here is an example of the xacml request if you are looking for one.
https://developer.cisco.com/site/curri/learn/how-to/read-call-routing-request/
if that's not what you want i would suggest reach out to the devnet forum about this.
https://communities.cisco.com/community/developer
-Atul
HI Atul Gaba
Thanks for you reply.
now i want to known how should i config,the CUCM will send the HTTP use this format
-Atul
who define this request's format ,the URL or CUCM default will use this format
