CUCM force encryption for all phone calls
TTrebing
Level 4
Level 4
Is there any way to enforce encryption on calls so that a call is not completed if it cannot be encrypted?
For example, security mode on the cluster is "mixed".  Phone A is setup to support encryption, while phone B is not.  When phone A calls phone B, the call is not encrypted, but is successful.  Is there a way to make the call to phone B fail since phone B is not capable of encryption.  I believe based on my research that the answer is "no", but I need official confirmation from Cisco.
Thanks!
Jaime Valencia
AFAIK you got this right, it's not possible to configure a cluster to prevent non-secure calls, there already some things that are non-secure, like MOH, if that was possible, you'd lose some features because of that.
java
if this helps, please rate
justin-puckett
In CUCM, under "System -> Service Parameters" (CUCM server and Cisco CallManager Service).  Under the Clusterwide Parameters (Feature - General) section, set "Block Unencrypted Calls" to "True"
Nice find Justin.
has it actually been proven working? and would it effect MOH like Jaime mentions?
+5!
Please remember to rate useful posts, by clicking on the stars below.
