CUCM in a cluster and redundancy
sarahr202
Level 5
Level 5
Hi everybody.
Please consider the following example:
                                   (1-100 phones)-----CM1------PUB-----CM2(101-200)
CM1 controls 1-100 phones; CM2 controls 101-200 phones. Publisher is not controlling any phones
My question is how does Cluster provide redundancy if CM1 goes down ?
I am just going on my  hunch here.
1-100 phones uses Call manger group as"
CM1
CM2
So after phones in 1-100 group does not receive the response from CM1 for keep alive, phones in 1-100 group contact the Cm2 and register with them.
Is this how we provide redundancy in a cluster?
thanks and have a great day.
2 Accepted Solutions
Jaime Valencia
Yes, via the CUCM group in which you define up to 3 servers in order of preference.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
In addition to correct answers by my colleagues here, when building CM groups you need to obey few rules which are described in SRND. I realize your environment is small so this may not apply, but it is important to know of future.
  • Cisco only supports 1:1 and 2:1 redundancy model, I see all kinds of unsupported deployments that end up in N:1 model, this leads to potential overload of backup servers.  Pay special consideration when clustering across WAN.
  • Yon need to ensure that the backup server is as powerful or more than the primary call processor it back up.
  • You should not be running CM process on Pub for environments with over 1250 devices.
HTH,
Chris
Pls check this system guide URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmsys/a02redun.html#wp1020927
//Suresh Please rate all the useful posts.
Jaime Valencia
java
java
HTH,
Chris
