CUCM on MCS, Rack mount server and Blade server!
Pointbreak
Hi Team,
What would be the main difference of installing CUCM on MCS, Rack mount and Blade server. Take an example with 3000 VOIP end points.
Jaime Valencia
You need to elaborate on exactly what you want to compare, in the end, unless it's CUCM 10.x+, you can build a system for that many phones in any platform.
If you're looking for general comparison on MCS Vs. virtualization, you can find plenty of info by googling the benefits of virtualization.
java
if this helps, please rate
