02-02-2017 12:34 AM - edited 03-17-2019 09:22 AM
We already have CUCM PUB/SUB installed at our HQ and now we are coming up with a new branch site having 250-300 users approx. The latency between HQ and branch site is around 50ms on VPN tunnel and in future, we are planning to set an MPLS link between HQ and branch site.
My question is whether to deploy a CUCM SUB node at branch site or to
Mohit
02-02-2017 05:36 AM
Mohit,
Here are a few things to consider:
Brandon
02-05-2017 11:50 PM
Hi Brandon,
1. Yes, we will deploy a local PSTN gateway at that site.
3. We don't have other sites like this. Few remote office with
4. The bandwidth between HQ and branch site is 80 Meg
I have few questions :
1. We already have enhanced workspace licenses. Can you how SUB will be costlier than E-SRS
2. What are the cons of using
3. If we choose SRST
4. Can E-SRST router and SRST manager be deployed at different sites over
5. We have VMware ESXi 5.5 host with Processor Type AMD Opteron Processor 6380. Does SRST Manage or CUCM Virtual machines support this processor type?
Mohit
02-06-2017 12:11 PM
1. From a cost perspective, the hardware for an additional subscriber would be more than utilizing an existing gateway to run SRST. Even if the gateway is not existing, you will need to purchase either way.
2. SRST does not have all of the features of CUCM.
3. You can use SRST manager, but it is not necessary. Especially for one site.
4. Yes
02-08-2017 12:41 AM
1. If SRST manager is not present then how data sync between CUCM and E-SRST ISR would work?
2. SUB will be virtual, I am not sure how that would add to hardware cost since we already have ESXi servers at the branch site. And also we have the enhanced workspace licenses. Does install a SUB requires a node license as well ??
3. I don't think AMD processors aren't supported with UC apps. http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/collaboration-virtualization-hardware.html#processor
Can you please confirm?
Mohit
02-08-2017 11:00 AM
1. Without SRST manager you would need to add the configuration manually and make changes manually. With a small number of sites and relatively few changes this should not be a problem. Large scale deployment would benefit greatly from SRST manager.
2. Yes, you will need a node license. If the subscriber is virtual this license would be the only additional cost.
3. Correct. See below.
"Other CPU vendors such as AMD are not supported for UC."
