CUCM outgoing call issue
dreams_as_money
Recently  outgoing calls stopped working. I check the logs  and saw that called number and calling number the same. How it can be? Can someone explain me? What is the core cause for this?>
But it happens even when outgoing calls working. I will put here two logs one when calls not working one when it works
Calling Number=xxxxxx
Called Number=yyyyyyy
 when it is not working:
Received:
INVITE sip:yyyyyyy@10.30.25.1:5060 SIP/2.0
Via: SIP/2.0/TCP 10.30.25.10:5060;branch=z9hG4bK19ae4cf7bc4ec16
From: <sip:xxxxxxxxx@10.30.25.10>;tag=83139300~47306e48-507c-4cfb-a2ee-aa24ebb5f76e-26281450
To: <sip:yyyyyyyy@10.30.25.1>
Date: Tue, 26 Sep 2017 06:57:55 GMT
Call-ID: 44de100-9c91fa73-cde96f-a191e0a@10.30.25.10
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.30.25.10:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Session-ID: 00007e9700105000a0000014d114277a;remote=00000000000000000000000000000000
Cisco-Guid: 0072212736-0000065536-0000961480-0169418250
Session-Expires: 1800
P-Asserted-Identity: <sip:xxxxxxxx0@10.30.25.10>
Remote-Party-ID: <sip:xxxxxxxxxx@10.30.25.10>;party=calling;screen=yes;privacy=off
Contact: <sip:xxxxxxxxxx@10.30.25.10:5060;transport=tcp>;video;audio;+u.sip!devicename.ccm.cisco.com="CSF1111";bfcp
Max-Forwards: 69
Content-Length: 0
Sep 26 10:57:55.208: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=yyyyyyy, Called Number=yyyyyyyy, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=yyy
Result=Success(0) after DP_MATCH_DEST
Sep 26 10:57:55.208: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=yyyyyyy, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 26 10:57:55.208: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=2
2: Dial-peer Tag=17
When it is  working:
Sep 27 15:57:42.457: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.30.25.10:5060;branch=z9hG4bK19cf36a7de77808
From: <sip:1xxxxxxxx@10.30.25.10>;tag=83421510~47306e48-507c-4cfb-a2ee-aa24ebb5f76e-26334245
To: <sip:yyyyyyy@10.30.25.1>
Date: Wed, 27 Sep 2017 11:57:42 GMT
Call-ID: fce0480-9cb19236-cefd2e-a191e0a@10.30.25.10
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Session-ID: 000075dd00105000a0000014d114277a;remote=00000000000000000000000000000000
Cisco-Guid: 0265159808-0000065536-0000967097-0169418250
P-Asserted-Identity: <sip:xxxxxxxxx@10.30.25.10>
Remote-Party-ID: <sip:xxxxxxxx@10.30.25.10>;party=calling;screen=yes;privacy=off
Contact: <sip:xxxxxxxx@10.30.25.10:5060;transport=tcp>;video;audio;+u.sip!devicename.ccm.cisco.com="CSF1111";bfcp
Max-Forwards: 69
Content-Length: 0
Sep 27 15:57:42.457: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=yyyyyyyyy, Called Number=yyyyyyyyy, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=yyyyyyyy
Sep 27 15:57:42.457: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=yyyyyyyyyy, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 27 15:57:42.457: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=2
2: Dial-peer Tag=17
3: Dial-peer Tag=52
Sep 27 15:57:42.457: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=xxxxxxxxxx, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=13
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Calling Number=xxxxxxxxx, Called Number=, Voice-Interface=0x0,
Thank you
0 Replies 0
