CUCM Pen Testing Vulnerability
Humza Khan
One of our client done netwrok pen testing. Following are the findings of PEN testing for our cisco equipment, we need to fix this vulnerability ASAP.
Suggested by pen testing team.
NTP monlist Command Enabled Risk Rating Medium Vulnerability Description
The version of ntpd on the remote host has the 'monlist' command enabled. This command returns a list of recent hosts that have connected to the service. As such, it can be used for network reconnaissance or, along with a spoofed source IP, a distributed denial of service attack Remediation steps
If using NTP from the Network Time Protocol Project, either upgrade to NTP 4.2.7-p26 or later, or add 'disable monitor' to the 'ntp.conf' configuration file and restart the service. Otherwise, contact the vendor. Otherwise, limit access to the affected service to trusted hosts
Affected Hosts
Host                    192.192.10.20                     (CUCM IP Publisher)
Port                     123
KIndly suggest, what we do to this request.
Humza Khan
CVE are assigned for commonly known security vulnerabilities. I have highlighted in Blue in my previous post.
As said before, check with TAC for the most appropriate workaround.
And by the way your CUCM version is very old and will be out of TAC support :
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-callmanager/end_of_life_notice_c51-695269.html
Last Date of Support:
App. SW
The last date to receive service and support for the product. After this date, all support services for the product are unavailable, and the product becomes obsolete.
June 30, 2015
-Terry
Please rate helpful posts
Terry Cheema
Humza Khan,
You haven't listed the version of CUCM and any CVE mentioned by your tester but still refer  to below BUG
https://tools.cisco.com/bugsearch/bug/CSCus26858
Cisco Call Manager (CUCM)includes a version of NTPd that is affected by the vulnerability identified by the Common Vulnerability and Exposures (CVE) IDs:
CVE-2014-9293 CVE-2014-9294 CVE-2014-9295 CVE-2014-9296
This product only allows processing of NTP control messages locally.
It appears to me your vulnerability is covered by this BUG. Most of the times you need to upgrade the CUCM to mitigate these threats.
Compare your information with this bug and open a TAC case and upgrade to TAC recommended version, usually there are no work arounds in such cases.
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries.
Hi Terry,
Thanks for your swift response, our client is using CM version is 7.1.5.
I am unable understand your sentence "any CVE mentioned by your tester".
Kindly elaborate.
Humza Khan
App. SW
June 30, 2015
-Terry
Hi Terry,
Thanks for your entire support. Your opinion is very helpful for me. So in this case we need to suggest our client to upgrade CUCM.
Humza Khan
