05-13-2015 08:03 AM - edited 03-17-2019 02:59 AM
Can you guys please help with an issue I am having. We are currently running CUCM v10.0 single cluster with remote sites. We recently added a new remote site but have been experiencing some difficulties. Apparently when the lines go idle for more than 30 minutes our user at the branch are no longer able to make outgoing PSTN calls.
However, if you were to call in to the site it would be successful and afterwards users would be able to make outgoing PSTN calls again. We have a gateway at the site a CISCO2901/K9 with 4 FXO ports and 1 E1 controller. The problem occurs when trying call via the E1 lines and via the FXO ports.
Please help.
Thanks a lot in advance.
05-13-2015 08:09 AM
One thing I forgot to include was the trace logs. Please note the Rejected Status:
2015/05/13 06:48:27.166|CC|SETUP|49091840|49091841|1359|92025466|92025466
2015/05/13 06:48:32.178|SIPL|49091840|TCP|OUT|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22310^172.17.11.38^*|78883914|6cfa8902-42100192-23ba6b7a-6ccdcfda@172.17.11.38|480 Temporarily Not Available
2015/05/13 06:48:32.188|SIPL|49091840|TCP|IN|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22313^172.17.11.38^*|78883915|6cfa8902-42100192-23ba6b7a-6ccdcfda@172.17.11.38|ACK
2015/05/13 06:48:32.189|CC|REJECT|49091840|49091841|1359|92025466|92025466|41
2015/05/13 06:48:45.206|CC|REJECT|49091842|49091843|813444111|2277032|2277032|1
2015/05/13 06:49:04.499|CC|REJECT|49091845|49091846|813444111|2277032|2277032|1
2015/05/13 06:51:47.584|SIPL|0|TCP|IN|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22317^172.17.11.38^*|78884781|6cfa8902-42100194-03204896-7425159b@172.17.11.38|INVITE
2015/05/13 06:51:47.586|SIPL|0|TCP|OUT|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22317^172.17.11.38^*|78884782|6cfa8902-42100194-03204896-7425159b@172.17.11.38|100 Trying
2015/05/13 06:51:51.233|CC|SETUP|49091848|49091849|1359|92025466|92025466
2015/05/13 06:51:56.245|SIPL|49091848|TCP|OUT|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22326^172.17.11.38^*|78884863|6cfa8902-42100194-03204896-7425159b@172.17.11.38|480 Temporarily Not Available
2015/05/13 06:51:56.258|SIPL|49091848|TCP|IN|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22329^172.17.11.38^*|78884864|6cfa8902-42100194-03204896-7425159b@172.17.11.38|ACK
2015/05/13 06:51:56.259|CC|REJECT|49091848|49091849|1359|92025466|92025466|41
2015/05/13 06:52:07.093|SIPL|0|TCP|IN|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22334^172.17.11.38^*|78884962|6cfa8902-42100196-58d34767-20d5e046@172.17.11.38|INVITE
2015/05/13 06:52:07.094|SIPL|0|TCP|OUT|172.17.*.*|5060|SEP6CFA89024210|172.17.11.38|51388|2,100,14,783262.22334^172.17.11.38^*|78884963|6cfa8902-42100196-58d34767-20d5e046@172.17.11.38|100 Trying
2015/05/13 06:52:11.515|CC|SETUP|49091850|49091851|1359|96102900|96102900
05-13-2015 02:37 PM
Hi Marcel.
Can you please also post your VG config?
Carlo
05-13-2015 02:59 PM
05-13-2015 01:10 PM
Is it a mgcp gateway? H323 gateway?
IOS of 2901?
05-13-2015 02:19 PM
H323 gateway.
(C2900-UNIVERSALK9-M), Version 15.2(4)M5
02-11-2016 07:07 AM
Hi Marcel,
did you find the solution for this problem?
Best regards.
