CUCM Sip trunk 404 loop
albrto1982
I have a cucm version 8.6.2 and a SIP trunk with a SBC. 172.23.129.8 is the CUCM and 172.23.129.35 is the SBC
I want to know how can i avoid 404 loop.
Hi.
Did you check these two service parameters value on CUCM?
Stop   Routing on Unallocated Number Flag
Stop   Routing on User Busy Flag
Ensure that they are on "True" Value
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
You did the trick!!!
I enabled "Stop   Routing on Unallocated Number Flag"
Thank you so much.
