01-29-2015 02:44 AM - edited 03-17-2019 01:45 AM
hi guys
i need assistance here asap!!!!
i configure sip trunk (cucm ver 8.6) to coral pbx
i register vg224 to my cucm manager (sccp protocol) and connect to him analog modem fro test....
on the coral pbx i also connect analog modem and made a connection test between.
the resualt was "not answer" in my modem that connect to vg224.
if i do tahe same test and dial threw pstn (not over sip trunk) the connection is fine!
i need to know whiche appropiate configuration on vg224 or cucm sip trunk that match.
i attach the vg224 configuration ....
sip trunk in cucm with defualt configuration...
tk
shoham
01-29-2015 07:22 AM
This is Video Over IP, please move to a relevant area.
01-29-2015 07:36 AM
correct!!
moved....
tk
shoham
01-29-2015 08:42 AM
VG224 is FXS Gateway
But as I understand U need FXO Gateway
01-29-2015 09:12 AM
hi
no,the fxs port connect to the modem and dial over sip trunk (cucm manager) to other modem that connect to coral pbx. the filure is happened only threw sip trunk
if i dial threw pstn ,its fine!
i recive "no answer" from the remote modem....
hope its more clear for u now....
tk
shoham
