cucm sip trunk between analog vg224(analog modem connect to) to coral pbx (analog modem connect) issue
shohamshalom
hi guys
i need assistance here asap!!!!
i configure sip trunk (cucm ver 8.6) to coral pbx
i register vg224 to my cucm manager (sccp protocol) and connect to him analog modem fro test....
on the coral pbx i also connect analog modem and made a connection test between.
the resualt was "not answer" in my modem that connect to vg224.
if i do tahe same test and dial threw pstn (not over sip trunk) the connection is fine!
i need to know whiche appropiate configuration on vg224 or cucm sip trunk that match.
i attach the vg224 configuration ....
sip trunk in cucm with defualt configuration...
tk
shoham
Jaime Valencia
This is Video Over IP, please move to a relevant area.
java
if this helps, please rate
correct!!
moved....
tk
shoham
VG224 is FXS Gateway
But as I understand U need FXO Gateway
hi
no,the fxs port connect to the modem and dial over sip trunk (cucm manager) to other modem that connect to coral pbx. the filure is happened only threw sip trunk
if i dial threw pstn ,its fine!
i recive "no answer" from the remote modem....
hope its more clear for u now....
tk
shoham
