CUCM SQl CLI command
j.huizinga
Level 6
Level 6
On Callmanager the following will give the phones where CFA is set:
run sql select d.name as device, n.dnorpattern, cfd.cfadestination from device as d inner join devicenumplanmap as dmap on dmap.fkdevice=d.pkid inner join numplan as n on dmap.fknumplan=n.pkid inner join callforwarddynamic as cfd on cfd.fknumplan=n.pkid where (cfd.cfadestination!='')
I am looking for the command to get other forwards, like the busy and RNA
Anyone?
JH
For Call Forward No Answer,
run sql select d.name as device, n.dnorpattern, n.cfnadestination from device as d inner join devicenumplanmap as dmap on dmap.fkdevice=d.pkid inner join numplan as n on dmap.fknumplan=n.pkid where (n.cfnadestination!='')
For Call Forward Busy,
run sql select d.name as device, n.dnorpattern, n.cfbdestination from device as d inner join devicenumplanmap as dmap on dmap.fkdevice=d.pkid inner join numplan as n on dmap.fknumplan=n.pkid where (n.cfbdestination!='')
For Call Forward Unregistered,
run sql select d.name as device, n.dnorpattern, n.cfurdestination from device as d inner join devicenumplanmap as dmap on dmap.fkdevice=d.pkid inner join numplan as n on dmap.fknumplan=n.pkid where (n.cfurdestination!='')
Tagir Temirgaliyev
what version cucm u are talking about
j.huizinga
Level 6
Level 6
Thank you so much Mohammed!
Is there information about SQL database of Cisco?
Thanks!
Jan
Look for Data Dictionary based on your CUCM version.
Also, this is a good document created by TAC. Worth reading it.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117726-technote-cucm-00.html
