CUCM SQL Query
kumar4321
I need to extract and then update the Enterprise Alternate Number for a large number of DNs. Can I request some help to know in which SQL table is the Enterprise Alternate Number stored. I thought it will be in table numplan but I could not find it there.
2 Accepted Solutions
Ishan Zutshi
hi,
did you try this?
run sql select * from alternatenumber
thanks,
Ishan
thanks, there are two columns dnormask and dnderived where the alternate number seems to be stored. In my CUCM, both contain the same value. Not sure if I have to update the new alternate number in one or both columns. But I can do trial and error to figure that. Many thanks for your help.
Ishan Zutshi
hi,
did you try this?
thanks,
Ishan
