cucm to cube to sip trunk provider
dantellana
I am Danny
I would like to ask help on how to configure cucm-cube-sip trunk provider or any basic guide for this?
the sip trunk provider only gave me:
cisco 1900 router
IP address
dial block.
available on our end is
BE6K - cucm, unity, IMPresnece
cisco 2911 router
thank you
17 Replies 17
I dont see any matching outgoing dial-peer.
dial-peer voice 100 voip
 incoming called-number .%
 no vad
dial-peer voice 200 voip
 destination-pattern 0822877730.......
 session protocol sipv2
 session target ipv4:10.1.45.20             ( IP from Sip provider router interface)
dial-peer voice 300 voip
 session target ipv4:192.168.50.10          ( CUCM IP address )
 incoming called-number 0822877730.......
Please refer to below doc, on how to configure inbound and outbound dial-peers.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Hi Aramared
please see my attached log. my outgoing dial-peer to be paired is 082.......
which is I dialed @ my CUCM 0823055942
:( I can't get it working
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.10 15:48:56 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
CUBE>en
Password:
CUBE#show run
Building configuration...
Current configuration : 2096 bytes
! Last configuration change at 07:20:03 UTC Tue Feb 10 2015
! NVRAM config last updated at 07:20:05 UTC Tue Feb 10 2015
version 15.1
hostname CUBE
boot-start-marker
boot-end-marker
enable password password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
voice service voip
 ip address trusted list
  ipv4 10.1.45.20
  ipv4 192.168.50.10
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  midcall-signaling passthru
  pass-thru content sdp
license udi pid CISCO2901/K9 sn FGL171622TN
hw-module pvdm 0/0
redundancy
interface GigabitEthernet0/0
 ip address 10.1.45.3 255.255.255.0
 duplex auto
 speed auto
 ip address 192.168.50.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.1.45.1
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
 destination-pattern 082.......
 dtmf-relay rtp-nte
 no vad
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0
 password password
 login
 transport input all
line vty 1 4
 login
 transport input all
scheduler allocate 20000 1000
end
CUBE#deb
CUBE#debug voice
CUBE#debug voice ccap
CUBE#debug voice ccapi inout
voip ccapi inout debugging is on
CUBE#deb
CUBE#debug ccsi
CUBE#debug ccsip mess
CUBE#debug ccsip messages
SIP Call messages tracing is enabled
CUBE#clear
CUBE#clear logg
Clear logging buffer [confirm]
CUBE#show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 2626 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 1298 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 2626 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 99 message lines logged
Log Buffer (8192 bytes):
-212988D7@192.168.50.1
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0443218688-0000065536-0000000060-0171092160
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1423552969
Contact: <sip:200@192.168.50.1:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Length: 0
Feb 10 07:22:50.163: //41/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0823055942@10.1.45.20:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.50.1:5060;branch=z9hG4bK517A6
Remote-Party-ID: "DEMO" <sip:200@192.168.50.1>;party=calling;screen=yes;privacy=off
To: <sip:0823055942@10.1.45.20>
Date: Tue, 10 Feb 2015 07:22:50 GMT
Call-ID: 73D8D3D4-B02C11E4-8099B5A0-212988D7@192.168.50.1
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423552970
Expires: 180
Max-Forwards: 69
Content-Length: 0
Feb 10 07:22:51.163: //41/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 10 Feb 2015 07:22:51 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423552971
Expires: 180
Max-Forwards: 69
Content-Length: 0
Feb 10 07:22:53.163: //41/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 10 Feb 2015 07:22:53 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423552973
Expires: 180
Max-Forwards: 69
Content-Length: 0
Feb 10 07:22:57.163: //41/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 10 Feb 2015 07:22:57 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423552977
Expires: 180
Max-Forwards: 69
Content-Length: 0
Feb 10 07:23:05.163: //41/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 10 Feb 2015 07:23:05 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423552985
Expires: 180
Max-Forwards: 69
Content-Length: 0
Feb 10 07:23:06.743: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:0823055942@192.168.50.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.50.10:5060;branch=z9hG4bK3b50f5f3c2
From: "DEMO" <sip:200@192.168.50.10>;tag=61~7f88b1b9-f68d-4857-b8e0-e411cd112197-23459567
To: <sip:0823055942@192.168.50.1>
Date: Tue, 10 Feb 2015 07:40:39 GMT
Call-ID: 1a6afb00-4d91b5f7-3c-a32a8c0@192.168.50.10
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
Feb 10 07:23:06.743: //40/1A6AFB000000/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2A42D6F4, Call Id=40
Feb 10 07:23:06.747: //40/1A6AFB000000/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Feb 10 07:23:06.747: //41/1A6AFB000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Feb 10 07:23:06.747: //40/1A6AFB000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb 10 07:23:06.747: //40/1A6AFB000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 10 Feb 2015 07:23:06 GMT
CSeq: 101 CANCEL
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:0823055942@192.168.50.1>;tag=39564C-9F4
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=16
Content-Length: 0
Feb 10 07:23:06.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0823055942@192.168.50.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: presence, kpml
Content-Length: 0
Feb 10 07:23:06.751: //40/1A6AFB000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2A42D6F4, Tag=0x0, Call Id=40,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb 10 07:23:06.751: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 10 07:23:06.751: :cc_free_feature_vsa freeing 31839BE0
Feb 10 07:23:06.751:  vsacount in free is 1
CUBE#undeb
CUBE#undebug all
All possible debugging has been turned off
CUBE#exit
Configure below:
 no vad
 dial-peer voice 300 voip   ---->this is the dial-p towards CUCM
 destination pattern 0822877730.......----> mention here the range of CUCM DN's.
For incoming through this SIP trunk to reach CUCM DN's, provider will send some number, you need to configure accordingly in above dial-peer voice 300.
If your CUCM DNs are in range 21559 to 21889, you can configure in above dial-peer 300, destination-pattern as 21xxx.
If provoider is sending fufl DID number towards CUBE for incoming call, like  21246421559, then configure in above dial-peer 300, destination-pattern as 21246421xxx, then in the CUCM you can configure translation pattern to convert 21246421xxx to 21xxx, so that it rings phones with DNs 21xxx range in CUCM.
 dial-peer voice 100 voip     ---->this is the dial-p towards SIP provider
 destination-pattern 082....... ---->mention here the range for outgoing calls towards SIP provider.
 dtmf-relay rtp-nte
 no vad
 In the above dial-peer 100, mention the range for outgoing calls, the called numbers range which will be sent out from CUCBE towards SIP provider.
 ++++From debugs, CUBE is sending INvite Via  192.168.50.1, since you have given bind for media and signalling as GigabitEthernet0/1.
 Sent:
As you mentioned in your earlier note:  Signalling IP: 10.1.45.3(GigabitEthernet0/0) ( this is the IP they ask from us to be used for signalling)
Make below change:
conf t
voice service voip
sip
bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  Router# wr mem
