CUCM V7 CLI Issues
lee-h
I have a customer with Call Manager 7 with MGCP Gateway connected to PRI. The client wishes to supress the outbound CLI for two partitions. Is this possible, if it can how is this achieved ?
Many Thanks
Jaime Valencia
If you mean you got X amount of phones in 2 partitions and all those need not to send CLID, then, what you need to do is to create a separate route pattern for those phones to use and in which you disable the CLID
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
