IP Telephony and Phones
Labels
I do have a CME setup .All phones are working in sccp protocol.We have done the Natting private CME address to public ip.I gave the Public Ip address to  the remote ip phone ,But no luck.Phone Showing "Registering".I have opened the ports(Sccp-2000 a...
Hello Everyone,I have UC 560, ESW 520 48 port POE switch and window 2008 R2 server. My question is i have to use DHCP pool from my window 2008 R2 server.For that which changes i should make on UC 560?????? I know how to configure DHCP pool with optio...
Hi all, in a CUCME environment, is it possible for a 7945 for example,         to change the order of blf and speed dials. Because now, if i issue the command under ephone:blf-speed-dial 1 954 label "XXX" deviceblf-speed-dial 2 955 label "XYX" device...
dwtcp by Level 1
  • 1444 Views
  • 2 replies
Hi all,         I have a confusion regarding DID (direct inwards dialing).                  when an organization purchases a range of numbers for DID/DOD, does the organization have to use that range for internal and external purposes or else can we ...
I am trying to connect a Plantronics HW261N headset to a 7942 deskphone using a Plantronics adapter. I assume it should be as easy as connecting the headset/adapter to the back of the phone, but apparently not. There is no sound coming through the he...
I have below problem. I have added bulk speed dial list in CME which  has got entries like this.The prefix is #7933,934481800001,Test  user,hideIn above by dialing #7933 user will reach  the phone number 81800001 and 9344 is the destination pattern o...
Asim ali by Level 1
  • 2011 Views
  • 10 replies
