09-06-2012 09:01 AM - edited 03-16-2019 01:04 PM
Dear:
I need to add or merge with my CUCM 8.6 An MD 110 Aastra PBX H323 but not what steps to add these.
Please your understanding.
regards
09-06-2012 11:21 AM
You mean you want to integrate both systems??
If so, just look at what protocol both systems understand (SIP, H323) or TDM / T1 QSIG
If it's IP protocol just configure either a SIP trunk or H323 trunk/GW pointing to the other system.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-06-2012 01:25 PM
but not how to do it step by step I should add the H323 GW but I must create pattern in both voice and Call Router Manager.
