Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCME 8.1 and SRST on same router
etmarcof
Level 3
Level 3
I would like to know if its possible folowing scenario:
I have two sites  interconnected. In Main site i have one CUCM 7.1 and one 2821 gateway and in remote site i have CUCME 8.1. in a 2951 gateway.
My question is that if in this remote site that i have CUCME can i have configured one same router SRST for only two ip phones that i have to connected to CUCM  of main site because they are Agents of UCCX? All the other phones in remote site should be connected to CUCME in remote site. Is that possible?
Best Regards
MC
Adrian Saavedra
Level 7
Level 7
That's not possible. You can't use SRST if it's configured as CME.
Hope it helps, please rate if it does.
- Adrian.
