04-18-2016 04:52 PM - edited 03-17-2019 06:37 AM
Hi everyone, having an issue with a customer who has an issue forwarding calls from a secondary line. They button 6 configured as a normal extension. I have CFwdAll configured in the Seized portion of the ephone template. When they press button 6, the speaker phone auto answers. However the CFwdAll button is not functional. They then pickup the handset and the CFwdAll button then responds.
The reverse is also true. If they pickup the handset and press button 6, they then have to press the speaker button in able to use CFwdAll. Once they have gone through speaker to handset or vice-versa, they can forward that secondary line without issue. See a portion of the config and show version below. One thing to note is we do not have the issue mentioned above when forwarding line 1. Only line 2 on button 6. I've also moved this to another phone and other buttons with the same results.
ephone-dn 66 octo-line (primary line on button 1)
number 100 secondary 9500
call-forward busy 701
call-forward noan 701 timeout 45
ephone-dn 110 octo-line (secondary line on button 6)
number 200 secondary 2344
call-forward busy 709
call-forward noan 709 timeout 30
ephone 66
conference admin
device-security-mode none
ephone-template 2
type 7962 addon 1 7915-24 2 7915-24
keep-conference local-only
button 1:66 6:110 7w3 8w1
button 9w22 10w40 11w7 12w11
button 13w65 14w2 15w63 16w92
button 17w105 18w112 19w107 20w56
button 21w20 22w10 23w38 24w37
button 25w48 26w96 27w52 28w39
button 30w77 31w28 32w51 33w14
button 34w54 35w67 36w87 37w9
button 38w15 39w24 40w23 41w25
button 42w47 43w93 44w13 45w46
button 46w97 48w44 49w32 50w94
button 51w19 52w6 53w69 54w109
ephone-template 2
conference admin
softkeys hold Resume Newcall Select Join
softkeys seized Redial Endcall Cfwdall Meetme Callback
softkeys connected Hold Endcall Trnsfer Confrn Park TrnsfVM
telephony-service
sdspfarm units 4
sdspfarm tag 1 confbridge
conference hardware
max-ephones 110
max-dn 288
ip source-address 10.10.12.1 port 2000
calling-number initiator
service phone ehookEnable 1
service phone webAccess 0
timeouts interdigit 5
timeouts busy 25
timeouts ringing 25
url services http://10.10.12.2/voiceview/common/login.do
url authentication http://10.10.12.2/voiceview/authentication/authenticate.do
cnf-file perphone
load 7915-12 B015-1-0-3.SBN
load 7915-24 B015-1-0-3.SBN
load 7906 SCCP11.8-4-2S
load 7911 SCCP11.8-4-2S
load 7960-7940 P00308000500
load 7942 SCCP42.9-4-2SR1-1S
load 7945 SCCP45.9-4-2SR1-1S
load 7962 SCCP45.9-4-2SR1-1S
load 7965 SCCP45.9-4-2SR1-1S
time-zone 5
keepalive 10 auxiliary 10
voicemail 700
max-conferences 8 gain -6
call-park system application
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
log table retain-timer 30
log table max-size 100
secondary-dialtone 9
after-hours block pattern 2 91246....... 7-24
after-hours block pattern 4 91268....... 7-24
after-hours block pattern 6 91340....... 7-24
after-hours block pattern 7 91345....... 7-24
after-hours block pattern 8 91441....... 7-24
after-hours block pattern 10 91649....... 7-24
after-hours block pattern 11 91664....... 7-24
after-hours block pattern 12 91700....... 7-24
after-hours block pattern 13 91758....... 7-24
after-hours block pattern 14 91767....... 7-24
after-hours block pattern 15 91784....... 7-24
after-hours block pattern 19 91868....... 7-24
after-hours block pattern 20 91869....... 7-24
after-hours block pattern 21 91876....... 7-24
after-hours block pattern 22 91900....... 7-24
after-hours block pattern 23 91976....... 7-24
after-hours block pattern 24 91976....... 7-24
create cnf-files version-stamp 7960 Apr 07 2016 10:53:58
OutputCommand base-URL was: /level/15/exec/-
Complete URL was:/level/15/exec/-/sho/ver/CR
Command was: sho ver--------------------------------------------------------------------------------
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_SNA-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 24-Mar-15 09:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
PBSM-MDF-2851Gw uptime is 3 days, 12 hours, 21 minutes
System restarted at 02:02:50 PDT Fri Apr 15 2016
System image file is "flash:c2800nm-adventerprisek9_sna-mz.151-4.M10.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 1.0) with 1028096K/20480K bytes of memory.
2 Gigabit Ethernet interfaces
24 Serial interfaces
1 terminal line
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
2 Voice E & M interfaces
1 cisco Integrated Service Engine(s)
Cisco Unity Express 8.5.1 in slot/sub-slot 1/0
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2851
