CUE 7.0.3 forget CLI user name and password
ichehouri
Level 2
Level 2
i have CUE v7.0.3 and iam able to access from the GUI but facing problem when trying with CLI (SSH). is there any way to reset the password from the GUI or any other way
regards,
Ibrahim
Hi Ibrahim,
First of all to make sure there are not surrent connections to CUE that make it busy do the following:
service-module integrated-Service-Engine 0/0 session clear
then check how it goes?
in order to reset the password try this ocmmand:
service-module integrated-Service-Engine 0/0 password-reset
B.R/Haitham
If you find this helpful, Please Rate
6 Replies 6
dijohn
Factory Reset should help.
Step 1: Session into CUE using the command service-module Integrated-Service-Engine 0/0 session. (Hit ‘enter’ twice to get a prompt).
Step 2: Type ‘offline’ to go into the offline mode.
Step 3: Type in ‘y’ when you are prompted with ‘Are you sure you want to go offline[n]?’
Step 4: Type in ‘restore factory default’
Step 5: Type in ‘y’ when you are prompted with ‘Do you wish to continue[n]?’
Step 6: Press the Enter key when prompted to ‘Press any key to reload:’
This reset can take 5-10 minutes. Wait until the CUE message ‘SYSTEM ONLINE’ is displayed before proceeding.
Step 7: Exit the CUE by typing ‘exit’.
dijohn
Alternatively,
You can do the following ...
Note: If you get a message like this:
vnt-3745-41a#service-module service-Engine 4/0 session
Trying 172.18.106.66, 2129 ...
% Connection refused by remote host
Clear the TTY line in question. In this case, it is 129 (2129 - 2000). You can also see this in the output of the service-module service-Engine 4/0 statuscommand output. The output states Service Module supports session via TTY line 129. In order to clear the line, enter the clear line 129command and press enter in order to confirm. Then repeat the service-module service-Engine 4/0 session command.
View All Cisco Unity Express Users
Now you can view all the users on the Cisco Unity Express system with the show users command:
cue-3745-44a>show users
pparker
ckent
bwayne
marschne
jdoe
View Cisco Unity Express Group Members
Look at the members of the Administrators group that use the show group detail groupname Administrators command in order to see which users have administrative rights:
cue-3745-44a>show group detail groupname Administrators
Full Name:          Administrators
Description:
Phone:
Phone(E.164):
Language:           systemDefault(en_US)
Owners:
Members:            marschne ckent
Privileges:         superuser ManagePrompts ManagePublicList ViewPrivateList
Note: The groupname (Administrators) is case sensitive. If you use "administrators" instead, you get a message that says Group administrators does not exist.
Create a New User
Use the user create command to create a new user. In this example, the new user is "Administrator":
cue-3745-44a>user Administrator create
Add a User to the Administrators Group
Assign the user to the Administrators group with the user group Administrators command.
cue-3745-44a> user Administrator group Administrators
Now you can verify the group membership with the show group detail groupname Administrators command.
Reset the Account Password
This user requires a valid password. In order to change a password (you are unable to view a forgotten password), use the user password command:
cue-3745-44a> user Administrator password cisco
You are now able to use a browser in order to access the Cisco Unity Express GUI and log in with the new username and password
Refer ..
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_password_recovery09186a008042aa29.shtml#c1
PS: Rate posts if they are helpful
dijohn
Can you post a sh run of your Router NOT CUE.
Are you being asked for a username/password after "service-module service-enging 0/0 session"?
yes i am getting user name/ password after service-module service-enging 0/0 session. i do not want to make factory default since there is existing configuration and running. For the GUI, it is ok and i can access
below partial show runn for router (X.X.X.X is just hidden information):
Current configuration : 23717 bytes
version 12.4
service password-encryption
hostname AR36-THL-LECHATEAU-254
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096 informational
enable secret 5 $1$Otk1$EUjcHX2FoHWYQSYmKg0.e/
enable password 7 130716180503077B7F75
aaa new-model
aaa group server tacacs+ BAJ
server 141.94.128.23
aaa authentication login no_tacacs line
aaa authentication login VTYSec group tacacs+ line
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
action-type stop-only
group tacacs+
aaa session-id common
clock timezone KSA 3
dot11 syslog
ip source-route
voice-card 0
dspfarm
dsp services dspfarm
crypto pki trustpoint TP-self-signed-4044205940
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4044205940
revocation-check none
rsakeypair TP-self-signed-4044205940
username cisco privilege 15 password 7 060506324F41
archive
log config
hidekeys
interface Loopback1
ip address X.X.X.X.255.255.255.255
interface Tunnel0
bandwidth 1024
ip address X.X.X.X 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication bajdmvpn
ip nhrp map multicast X.X.X.X
ip nhrp map X.X.X.X X.X.X.X
ip nhrp network-id 100000
ip nhrp holdtime 300
ip nhrp nhs X.X.X.X
ip nhrp nhs X.X.X.X
ip tcp adjust-mss 1360
ip ospf network broadcast
ip ospf priority 0
ip ospf mtu-ignore
qos pre-classify
cdp enable
tunnel source Loopback1
tunnel mode gre multipoint
tunnel key 100000
interface FastEthernet0/0
description <<< LAN Interface >>>
no ip address
duplex full
speed 100
interface FastEthernet0/0.1
description *** management virtual i/f ***
encapsulation dot1Q 36 native
interface FastEthernet0/0.2
description <<< BAJ Users virtual i/f >>>
encapsulation dot1Q 37
interface FastEthernet0/0.3
description <<< IPT virtual i/f >>>
encapsulation dot1Q 38
ip address 10.228.38.254 255.255.255.0
interface FastEthernet0/0.4
description <<< BAJ AJC virtual i/f >>>
encapsulation dot1Q 39
interface Service-Engine0/0
description <<< CUE i/f >>>
ip unnumbered FastEthernet0/0.3
service-module ip address 10.228.38.253 255.255.255.0
service-module ip default-gateway 10.228.38.254
interface FastEthernet0/1
description <<< WAN i/f >>>
ip address X.X.X.X 255.255.255.252
ip access-group Public-Interface-ACL in
duplex full
speed 100
router ospf 1
router-id X.X.X.X
log-adjacency-changes
network X.X.X.X 0.0.3.255 area 0
network X.X.X.X 0.0.0.255 area 0
router bgp 64836
no synchronization
bgp log-neighbor-changes
network X.X.X.X mask 255.255.255.255
neighbor X.X.X.X remote-as 65000
no auto-summary
ip default-gateway X.X.X.X
ip forward-protocol nd
ip route 10.228.38.253 255.255.255.255 Service-Engine0/0
ip http server
no ip http secure-server
ip access-list extended Public-Interface-Acl
permit tcp 192.168.255.0 0.0.0.255 any eq telnet
deny ip any any log
logging X.X.X.X
logging X.X.X.X
access-list 2 permit X.X.X.X
access-list 23 permit X.X.X.X 0.0.0.7
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 0
timeouts wait-release 1
connection plar opx 301
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
cptone BR
description fax-numb
caller-id enable
voice-port 0/0/2
cptone BR
caller-id enable
voice-port 0/0/3
cptone BR
caller-id enable
voice-port 0/1/0
cptone BR
connection plar opx 302
caller-id enable
voice-port 0/1/1
cptone BR
caller-id enable
voice-port 0/1/2
cptone BR
caller-id enable
voice-port 0/1/3
cptone BR
caller-id enable
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp fax t38 ecm
dial-peer cor custom
name men
name ladies
name guard
name internal
name private-bank
dial-peer cor list men
member men
dial-peer cor list ladies
member ladies
dial-peer cor list guard
member guard
dial-peer cor list internal
member internal
dial-peer cor list private-bank
member private-bank
dial-peer voice 300 voip
description <<< PSTN i/o call-elg
destination-pattern 3..
session protocol sipv2
session target ipv4:10.228.38.253
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 101 pots
corlist outgoing men
destination-pattern 9.T
port 0/0/1
dial-peer voice 102 pots
port 0/0/2
dial-peer voice 103 pots
corlist outgoing ladies
port 0/0/3
dial-peer voice 104 pots
port 0/1/0
dial-peer voice 105 pots
port 0/1/1
dial-peer voice 106 pots
port 0/1/2
dial-peer voice 107 pots
port 0/1/3
dial-peer voice 108 pots
corlist outgoing guard
description <<< PSTN i/o call-leg >>>
destination-pattern 9[1-9]T
port 0/0/2
forward-digits 7
dial-peer voice 109 pots
destination-pattern 90501234566
port 0/0/2
forward-digits 10
dial-peer voice 100 pots
port 0/0/0
telephony-service
no auto-reg-ephone
authentication credential Admin Admin
max-ephones 40
max-dn 40
ip source-address 10.228.38.254 port 2000
timeouts interdigit 5
system message Welcome to Al-Tahlia Branch
url services http://10.228.38.253/voiceview/common/login.do
url authentication http://10.228.38.254/CCMCIP/authenticate.asp
cnf-file location flash:
load 7911 SCCP11.7-2-1-0S.loads
load 7942 SCCP42.8-4-2S.loads
time-zone 31
voicemail 300
max-conferences 8 gain -6
moh BAJ-MoH2.au
multicast moh 239.1.2.12 port 2000
web admin system name Admin password Admin
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
login timeout 5 clear 17:00
after-hours block pattern 1 90
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys idle Newcall Login Cfwdall Gpickup
softkeys seized Endcall
softkeys alerting Endcall Callback
softkeys connected Hold Endcall Trnsfer Confrn
ephone-template 2
softkeys idle Newcall Cfwdall Gpickup
ephone-dn 1 dual-line
number 700
pickup-group 1000
label 700
description <<< Branch Manager >>>
name Branch manager
call-forward busy 300
call-forward noan 300 timeout 20
corlist incoming men
ephone-dn 2 dual-line
number 701
pickup-group 1000
label 701
name Branch manager
ephone-dn 3 dual-line
number 702
pickup-group 1000
label 702
description <<< RM 1 >>>
name RM 1
ephone-dn 4 dual-line
number 703
pickup-group 1000
label 703
description <<< Meeting Room >>>
name Meeting Room
ephone-dn 5 dual-line
number 704
pickup-group 1000
label 704
description <<< RM 2 >>>
name RM 2
ephone-dn 6 dual-line
number 705
pickup-group 1000
label 705
description <<< RM 3 >>>
name RM 3
ephone-dn 7 dual-line
number 706
pickup-group 1000
label 706
description <<>>
name RM 4
corlist incoming ladies
ephone-dn 8 dual-line
number 707
pickup-group 1000
label 707
description <<< Manager >>>
name Manager
ephone-dn 9 dual-line
number 205
pickup-group 1000
label 205
description <<< Tea Room >>>
name Tea Room
corlist incoming internal
ephone-dn 10 dual-line
number 200
pickup-group 1000
label 200
description <<< Operation Manager >>>
name Ops. Manager
ephone-dn 11 dual-line
number 201
pickup-group 1000
label 201
name Ops. Manager
ephone-dn 12 dual-line
number 202
pickup-group 1000
label 202
description <<< Cash Vault Room >>>
name Ops. Cash Vault Room
ephone-dn 13 dual-line
number 708
pickup-group 1000
label 708
description <<< Asst. Manager >>>
name Asst. Manager
ephone-dn 14 dual-line
number 100
pickup-group 1000
label 100
description <<< SSO-1 >>>
name SSO-1
ephone-dn 15 dual-line
number 101
pickup-group 1000
label 101
description <<< SSO-2 >>>
name SSO-2
ephone-dn 16 dual-line
number 750
pickup-group 2000
label 750
description <<< Ladies Branch Manager >>>
name Branch Manager
ephone-dn 17 dual-line
number 250
pickup-group 2000
label 250
description <<< Ladies Teller >>>
name Teller
ephone-dn 18 dual-line
number 150
pickup-group 2000
label 150
description <<< Ladies SSO>>>
name SSO
ephone-dn 19 dual-line
number 751
pickup-group 2000
label 751
name Branch Manager
ephone-dn 20 dual-line
number 252
pickup-group 2000
label 252
description <<< Ladies Tea Room >>>
name Tea Room
ephone-dn 21 dual-line
number 203
pickup-group 1000
label 203
description <<< Saftey Deposit Valt >>>
name Saftey Deposit Valt
ephone-dn 22 dual-line
number 204
pickup-group 1000
label 204
description <<< Men Tea Room >>>
name Tea Room
ephone-dn 23 dual-line
number 210
label 210
description <<< Men Computer Room >>>
name Computer Room
ephone-dn 24 dual-line
number 110
pickup-group 1000
label 110
description <<< Guard >>>
name Guard
corlist incoming guard
ephone 1
device-security-mode none
mac-address 0026.99ED.5E8E
ephone-template 1
type 7942
button 1:1
pin 1234
ephone 2
mac-address 0023.5E19.F98A
ephone-template 1
type 7911
button 1:2
pin 1234
ephone 3
mac-address 0026.9944.E4FC
type 7942
button 1:3
pin 1234
ephone 4
mac-address 0026.9944.DBB4
ephone-template 1
type 7942
button 1:4
pin 1234
ephone 5
mac-address 0026.99ED.5EB3
ephone-template 1
type 7942
button 1:5
pin 1234
ephone 6
mac-address 0026.9945.97A2
ephone-template 1
type 7942
button 1:6
pin 1234
ephone 7
mac-address 0026.99ED.5E08
ephone-template 2
type 7942
button 1:7
pin 1234
ephone 8
mac-address 0026.9944.47FF
ephone-template 1
type 7942
button 1:8
pin 1234
ephone 9
mac-address 0023.5E19.E9EB
ephone-template 2
type 7911
button 1:9
ephone 10
mac-address 0026.9944.0484
ephone-template 1
type 7942
button 1:10
pin 1234
ephone 11
mac-address 0023.5E19.FB6A
ephone-template 1
type 7911
button 1:11
pin 1234
ephone 12
mac-address 0023.5E19.EB83
ephone-template 2
type 7911
button 1:12
pin 1234
ephone 13
mac-address 0026.9945.9593
ephone-template 1
type 7942
button 1:13
pin 1234
ephone 14
mac-address 0026.9944.E38C
ephone-template 1
type 7942
button 1:14
pin 1234
ephone 15
mac-address 0026.9944.DE5D
ephone-template 1
type 7942
button 1:15
pin 1234
ephone 16
mac-address 0026.9945.46EB
ephone-template 1
type 7942
button 1:16
pin 1234
ephone 17
mac-address 0026.9944.DE99
ephone-template 1
type 7942
button 1:17
pin 1234
ephone 18
mac-address 0026.99ED.5E93
ephone-template 1
type 7942
button 1:18
pin 1234
ephone 19
mac-address 0023.5E19.E9C1
ephone-template 1
type 7911
button 1:19
pin 1234
ephone 20
mac-address 0023.5E19.EA56
ephone-template 2
type 7911
button 1:20
ephone 21
mac-address 0023.5E19.E962
ephone-template 1
type 7911
button 1:21
pin 1234
ephone 22
mac-address 0023.5E19.EB53
ephone-template 2
type 7911
button 1:22
ephone 23
mac-address 0023.5E19.F92E
ephone-template 1
speed-dial 1 90501111111
type 7911
button 1:23
pin 1234
ephone 24
mac-address 0023.5E19.F97F
ephone-template 2
after-hours exempt
username "baj24" password 1234
speed-dial 1 0599876785
type 7911
button 1:24
line con 0
privilege level 15
password 7 06040E2B42410A485146
login authentication no_tacacs
line aux 0
line 194
password 7 0822455D0A16
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0
privilege level 15
password 7 15100A060A2528757C62
logging synchronous
transport input all
line vty 1 4
privilege level 15
transport input all
line vty 5 15
privilege level 15
transport input all
scheduler allocate 20000 1000
end
regards,
Ibrahim
Hi Ibrahim,
B.R/Haitham
Hi Haitham,
thanks for the support. it is working now after the password-reset
regards,
Ibrahim
