CUE auto attendant busy signal
hello
i have a problem with cisco unity express auto attendant , i get a busy signal when making call to AA extension
debug ccsip all:
Mar 13 12:48:42.757: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2B83DFD0) with key=[16958] to table
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Mar 13 12:48:42.757: //605598/000000000000/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.757: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sip_md:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sip_ed:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.2.252 target_port : 5060
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [-8] in dial-peer [2001]
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 93D9E to table
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=605597
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 28348 for stream 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2B83DFD0 key=2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.2.252,Port 5060, Transport 2, SentBy Port 5060
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:3246A5BC
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLMain:
    SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
    Configured SE:1800, Configured Min-SE:1800
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_handle_network_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (605598) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPISendInvite: Associated container=0x3246A5BC to Invite
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: msg=0x2B96BE78, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=2, switch=0, callBack=0x251CB50C
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x2AF8EDE0,addr=192.168.2.252
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnHolder: Created new holder=0x2AF8EDE0, addr=192.168.2.252; nailed=FALSE
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting TCP conn create request for addr=192.168.2.252, port=5060, context=0x3177B244
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x2AEC1ABC,addr=192.168.2.252, port=5060
Wait Conn Timer started for 5000 msec
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x2AEC1ABC, connid=-1, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, transport=TCP
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B83DFD0 with connection=0x2AEC1ABC
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: Deferred sending msg=0x2B96BE78
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUpdateCallEntry:
Call 605598 set InfoType to SPEECH
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 56
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionCreated: context=0x3177B244
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: gConnTab=0x3177B244, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connid=3, transport=TCP
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:192.168.2.252, port:5060 local_addr=192.168.2.253 local_port=50234
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x2AEC1ABC, connid=3state to pending
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:192.168.2.252, port:5060)
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 57
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionFailed: context=0x3177B244
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnFailed: gConnTab=0x3177B244, addr=192.168.2.252, port=5060, local_addr = 192.168.2.253, transport=TCP
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x2AEC1ABC,addr=192.168.2.252, port=5060
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=1
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting TCP conn close for addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connid=3
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x2AEC1ABC, connid=3, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, transport=TCP
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 61
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Error/sipTransportPostSendFailure: Posting send failure msg
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 53
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_send_msg_failure: Send Error to 192.168.2.252:5060 for transport TCP
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:38, category:186
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[605598], src[6]
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(38) for outgoing call
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_purge_entry: Socket fd: 0 closed for connid 3 with address: 192.168.2.252, remote port: 5060
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:90740177 ConnTime 0
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2B83DFD0
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           :
Called Number            : 400
Source IP Address (Sig  ): 192.168.2.253
Destn SIP Req Addr:Port  : 192.168.2.252:5060
Destn SIP Resp Addr:Port : 192.168.2.252:5060
Destination Name         : 192.168.2.252
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.2.253
Source IP Port    (Media): 28348
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 93D9E
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[16958] removed.
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B83DFD0 key=2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_delete:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_delete:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 2B83DFD0
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[16958]
15 Replies 15
Chrysostomos_CY
Level 5
Level 5
Pls post the voip dial peer for autoattendant
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
dial-peer voice 2001 voip
description ** cue auto attendant number **
destination-pattern 400
b2bua
session protocol sipv2
session target ipv4:192.168.2.252
voice-class sip outbound-proxy ipv4:192.168.2.252
dtmf-relay rtp-nte
codec g711ulaw
no vad
Pls  use the below dial peer and send me the debug ccsip messages
Also can we have the full config
dtmf-relay rtp-nte
codec g711ulaw
no vad
Mar 13 13:28:19.169: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2B83DFD0) with key=[16969] to table
Mar 13 13:28:19.169: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Mar 13 13:28:19.169: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Mar 13 13:28:19.169: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Mar 13 13:28:19.169: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Mar 13 13:28:19.169: //605619/000000000000/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:19.169: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Mar 13 13:28:19.169: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/is_mode_sip_sip_md:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/is_mode_sip_sip_ed:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Mar 13 13:28:19.169: //605619/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Mar 13 13:28:19.173: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Mar 13 13:28:19.173: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:19.173: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Mar 13 13:28:19.173: //605619/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:19.173: //605619/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.2.252 target_port : 5060
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [2001]
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 93DB3 to table
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=605618
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/preprocessSetup:
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17790 for stream 1
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Mar 13 13:28:19.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Mar 13 13:28:19.173: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2B83DFD0 key=B41C689B-8B1811E2-AC15E1AE-D7673161@192.168.2.253
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = B41C689B-8B1811E2-AC15E1AE-D7673161@192.168.2.253
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.2.252,Port 5060, Transport 1, SentBy Port 5060
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:32469384
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_iwf_handle_network_event:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (605619) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPISendInvite: Associated container=0x32469384 to Invite
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipSPITransportSendMessage: msg=0x30C26A3C, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x251CB50C
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x30C26A3C
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x30C26A3C, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
Mar 13 13:28:19.177: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 605619) to the VOIP RTP library
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 192.168.2.253, lport = 17790, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
    src_callid = 605619, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
    media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPICreateRtpSession: sess: 317D6D8C do_rtcp:0
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Media/sipSPICreateRtpSession: stun is disabled
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/State/sipSPIChangeStreamState: Stream (callid =  605619)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Info/sipSPIUpdateCallEntry:
Call 605619 set InfoType to SPEECH
Mar 13 13:28:19.177: //605619/B41A9423AC10/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:400@192.168.2.252:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.253:5060;branch=z9hG4bK612234
To: <400>
Date: Wed, 13 Mar 2013 13:28:19 GMT
Call-ID: B41C689B-8B1811E2-AC15E1AE-D7673161@192.168.2.253
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3021640739-2333610466-2886787502-3613864289
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1363181299
Contact: <192.168.2.253:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 7535 6317 IN IP4 192.168.2.253
s=SIP Call
c=IN IP4 192.168.2.253
t=0 0
m=audio 17790 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Mar 13 13:28:19.181: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.2.252]:32777, local_address:[192.168.2.253]
Mar 13 13:28:19.181: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 13 13:28:19.181: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 13 13:28:19.181: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 13 13:28:19.181: //605619/B41A9423AC10/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <400>
CSeq: 101 INVITE
Content-Length: 0
Mar 13 13:28:19.181: //605619/B41A9423AC10/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 13 13:28:19.181: //605619/B41A9423AC10/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.2.252]:32777, local_address:[192.168.2.253]
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 486 Busy Here
To: <400>;tag=ds130f322c
CSeq: 101 INVITE
Content-Length: 0
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: B41C689B-8B1811E2-AC15E1AE-D7673161@192.168.2.253
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_DIALOG_ESTD
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPISendAck: Associated container=0x3246AF04 to Ack
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipSPITransportSendMessage: msg=0x324B6634, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x0
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x324B6634
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x324B6634, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 486
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[605619], src[4]
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(17) for outgoing call
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_call_statistics: Requesting stats for callid=605619
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/ccsip_call_statistics: Stats request failed for callid=605619, dstCallID=-1, rc=-7
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 13 13:28:19.221: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:90977822 ConnTime 0
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Media/sipSPIDestroyRtpSession: stream:320F78F0
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Call/sipSPICallInfo:
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 400
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17790
Disconnect Cause (CC)    : 17
Disconnect Cause (SIP)   : 486
Mar 13 13:28:19.221: //605619/B41A9423AC10/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 93DB3
Mar 13 13:28:19.225: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:400@192.168.2.252:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 13 13:28:34.169: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2B82D200) with key=[16970] to table
Mar 13 13:28:34.169: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Mar 13 13:28:34.169: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Mar 13 13:28:34.169: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Mar 13 13:28:34.169: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/sipSPIChangeState: 0x2B82D200 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_mode_sip_sip_md:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_mode_sip_sip_ed:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Mar 13 13:28:34.169: //605621/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:34.169: //605621/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:34.169: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.2.252 target_port : 5060
Mar 13 13:28:34.169: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [2001]
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 93DB5 to table
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=605620
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/preprocessSetup:
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 31324 for stream 1
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2B82D200 key=BD0C9DF3-8B1811E2-AC1BE1AE-D7673161@192.168.2.253
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = BD0C9DF3-8B1811E2-AC1BE1AE-D7673161@192.168.2.253
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.2.252,Port 5060, Transport 1, SentBy Port 5060
Mar 13 13:28:34.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:3246BBBC
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:34.173: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/ccsip_iwf_handle_network_event:
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Mar 13 13:28:34.177: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (605621) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sipSPISendInvite: Associated container=0x3246BBBC to Invite
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: msg=0x32332364, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x251CB50C
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:34.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x32332364
Mar 13 13:28:34.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x32332364, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
Mar 13 13:28:34.177: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/State/sipSPIChangeState: 0x2B82D200 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 605621) to the VOIP RTP library
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 192.168.2.253, lport = 31324, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
    src_callid = 605621, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sipSPICreateRtpSession: sess: 320F7004 do_rtcp:0
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Media/sipSPICreateRtpSession: stun is disabled
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/State/sipSPIChangeStreamState: Stream (callid =  605621)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Info/sipSPIUpdateCallEntry:
Call 605621 set InfoType to SPEECH
Mar 13 13:28:34.177: //605621/BD0B65A3AC16/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.2.253:5060;branch=z9hG4bK622049
To: <400>
Date: Wed, 13 Mar 2013 13:28:34 GMT
Call-ID: BD0C9DF3-8B1811E2-AC1BE1AE-D7673161@192.168.2.253
Min-SE:  1800
Cisco-Guid: 3171640739-2333610466-2887180718-3613864289
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1363181314
Expires: 180
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 970 3013 IN IP4 192.168.2.253
s=SIP Call
t=0 0
m=audio 31324 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.2.252]:32777, local_address:[192.168.2.253]
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Info/sipSPISendInvite: Associated container=0x3246BBBC to Invite
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: msg=0x32332364, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x0
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:34.837: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x32332364
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x32332364, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 13 13:28:34.837: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 13 13:28:34.841: //605621/BD0B65A3AC16/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <400>
CSeq: 101 INVITE
Content-Length: 0
Mar 13 13:28:34.841: //605621/BD0B65A3AC16/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 13 13:28:34.841: //605621/BD0B65A3AC16/SIP/State/sipSPIChangeState: 0x2B82D200 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Sent:
To: <400>
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.2.252]:32777, local_address:[192.168.2.253]
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Msg/ccsipDisplayMsg:
Received:
To: <400>;tag=dsf8096cb3
CSeq: 101 INVITE
Content-Length: 0
Cisco-Gcid: BD0C9DF3-8B1811E2-AC1BE1AE-D7673161@192.168.2.253
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_DIALOG_ESTD
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPISendAck: Associated container=0x3246906C to Ack
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: msg=0x32332364, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x0
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x32332364
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x32332364, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 486
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[605621], src[4]
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(17) for outgoing call
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/State/sipSPIChangeState: 0x2B82D200 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Received:
CSeq: 101 INVITE
Content-Length: 0
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sipSPISendAck: Associated container=0x3246B954 to Ack
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipSPITransportSendMessage: msg=0x2C35CFC0, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x251CD180
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2C35CFC0
Mar 13 13:28:34.845: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2C35CFC0, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:34.845: //605621/BD0B65A3AC16/SIP/Info/sentErrorResponseCallClose: Sent Error Response since the Gw is Shutdown
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:90979385 ConnTime 0
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/Media/sipSPIDestroyRtpSession: stream:324B4280
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/State/sipSPIChangeState: 0x2B82D200 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2B82D200
Calling Number           :
Called Number            : 400
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 31324
Mar 13 13:28:34.849: //605621/BD0B65A3AC16/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 93DB5
Mar 13 13:28:34.849: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 13 13:28:44.169: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2B85FB70) with key=[16971] to table
Mar 13 13:28:44.169: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Mar 13 13:28:44.169: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Mar 13 13:28:44.169: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Mar 13 13:28:44.169: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/sipSPIChangeState: 0x2B85FB70 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_mode_sip_sip_md:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_mode_sip_sip_ed:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Mar 13 13:28:44.169: //605623/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Mar 13 13:28:44.169: //605623/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:44.173: //605623/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 13:28:44.173: //605623/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:44.173: //605623/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.2.252 target_port : 5060
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [2001]
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 93DB7 to table
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=605622
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17716 for stream 1
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2B85FB70 key=C3027EF3-8B1811E2-AC21E1AE-D7673161@192.168.2.253
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = C3027EF3-8B1811E2-AC21E1AE-D7673161@192.168.2.253
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.2.252,Port 5060, Transport 1, SentBy Port 5060
Mar 13 13:28:44.173: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 13:28:44.173: //605623/C30146A3AC1C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:3246BB64
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/Session-Timer/sipSTSLMain:
    SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
    Configured SE:1800, Configured Min-SE:1800
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_iwf_handle_network_event:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/ccsip_iwf_process_event:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Mar 13 13:28:44.177: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (605623) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sipSPISendInvite: Associated container=0x3246BB64 to Invite
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipSPITransportSendMessage: msg=0x2B075EA4, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x251CB50C
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:44.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2B075EA4
Mar 13 13:28:44.177: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2B075EA4, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
Mar 13 13:28:44.177: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/sipSPIChangeState: 0x2B85FB70 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 605623) to the VOIP RTP library
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 192.168.2.253, lport = 17716, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
    src_callid = 605623, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sipSPICreateRtpSession: sess: 32334D84 do_rtcp:0
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Media/sipSPICreateRtpSession: stun is disabled
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/State/sipSPIChangeStreamState: Stream (callid =  605623)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Info/sipSPIUpdateCallEntry:
Call 605623 set InfoType to SPEECH
Mar 13 13:28:44.177: //605623/C30146A3AC1C/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.2.253:5060;branch=z9hG4bK6313FD
To: <400>
Date: Wed, 13 Mar 2013 13:28:44 GMT
Call-ID: C3027EF3-8B1811E2-AC21E1AE-D7673161@192.168.2.253
Min-SE:  1800
Cisco-Guid: 3271640739-2333610466-2887573934-3613864289
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1363181324
Expires: 180
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 2032 4614 IN IP4 192.168.2.253
s=SIP Call
t=0 0
m=audio 17716 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Mar 13 13:28:44.273: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.2.252]:32777, local_address:[192.168.2.253]
Mar 13 13:28:44.273: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 13 13:28:44.273: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 13 13:28:44.273: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <400>
CSeq: 101 INVITE
Content-Length: 0
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/State/sipSPIChangeState: 0x2B85FB70 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Received:
To: <400>;tag=ds813893c6
CSeq: 101 INVITE
Content-Length: 0
Cisco-Gcid: C3027EF3-8B1811E2-AC21E1AE-D7673161@192.168.2.253
Mar 13 13:28:44.273: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_DIALOG_ESTD
Mar 13 13:28:44.273: //605623/C30146A3AC1C/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPISendAck: Associated container=0x3246AD4C to Ack
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipSPITransportSendMessage: msg=0x2C35CFC0, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=1, switch=0, callBack=0x0
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2C35CFC0
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2C35CFC0, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connId=4 for UDP
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 486
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[605623], src[4]
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(17) for outgoing call
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/State/sipSPIChangeState: 0x2B85FB70 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/ccsip_call_statistics: Requesting stats for callid=605623
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/ccsip_call_statistics: Stats request failed for callid=605623, dstCallID=-1, rc=-7
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:90980328 ConnTime 0
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Media/sipSPIDestroyRtpSession: stream:324B6634
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/State/sipSPIChangeState: 0x2B85FB70 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2B85FB70
State of The Call        : STATE_DEAD
Calling Number           :
Called Number            : 400
Source IP Address (Sig  ): 192.168.2.253
Destn SIP Req Addr:Port  : 192.168.2.252:5060
Destn SIP Resp Addr:Port : 192.168.2.252:5060
Destination Name         : 192.168.2.252
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.2.253
Source IP Port    (Media): 17716
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Mar 13 13:28:44.277: //605623/C30146A3AC1C/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 93DB7
Mar 13 13:28:44.277: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 13 13:28:51.221: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[16969] removed.
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B83DFD0 key=B41C689B-8B1811E2-AC15E1AE-D7673161@192.168.2.253
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/ccsip_offer_ans_delete:
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/ccsip_iwf_delete:
Mar 13 13:28:51.221: //605619/B41A9423AC10/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 2B83DFD0
I am not sure if the cue(AA) is function properly
can you post the config related for cue into VG ?
The voicemail is working?
Do you have the proper licenses for AA?
And final can i have the output of the status of cue?
Example:
CME# service-module integrated-Service-Engine 0/0 status
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Generating configuration:
clock timezone Europe/Paris
hostname CabinetAmous
line console
system language preferred "fr_FR"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site name local
site-hostname 192.168.2.253
web credentials hidden "NwZxwNIdNpdYcprqAUCCvknfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end site
license agent max-sessions 9
privilege ViewRealTimeReports create
privilege manage-passwords create
privilege ManagePublicList create
privilege local-broadcast create
privilege manage-users create
privilege broadcast create
privilege vm-imap create
privilege ManagePrompts create
privilege ViewPrivateList create
privilege ViewHistoricalReports create
groupname Broadcasters create
username sfx11 create
username sfx13 create
username sfx7 create
username sfx19 create
username sfx15 create
username sfx18 create
username sfx17 create
username sfx12 create
username SFXSC create
username sfx16 create
username sfx4 create
username SFX create
username sfx3 create
username sfx5 create
username sfx10 create
username sfx6 create
username sfx9 create
username sfx8 create
username sfx14 create
username sfx2 create
username Admin create
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege manage-passwords description "Privilege to reset user passwords"
privilege ManagePublicList description "Privilege to manage public lists"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege ViewPrivateList description "Privilege to view private list"
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege ViewRealTimeReports operation report.realtime
privilege manage-passwords operation user.password
privilege manage-passwords operation user.pin
privilege manage-passwords operation system.debug
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege manage-users operation user.notification
privilege manage-users operation user.password
privilege manage-users operation user.remote
privilege manage-users operation user.configuration
privilege manage-users operation group.configuration
privilege manage-users operation user.pin
privilege manage-users operation system.debug
privilege manage-users operation user.mailbox
privilege broadcast operation broadcast.remote
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege vm-imap operation voicemail.imap.user
privilege ManagePrompts operation system.debug
privilege ManagePrompts operation prompt.modify
privilege ViewPrivateList operation voicemail.lists.private.view
privilege ViewHistoricalReports operation report.historical.view
groupname Administrators member Admin
groupname Broadcasters privilege broadcast
username sfx11 phonenumber "203"
username sfx13 phonenumber "250"
username sfx7 phonenumber "111"
username sfx19 phonenumber "332"
username sfx15 phonenumber "133"
username sfx18 phonenumber "350"
username sfx17 phonenumber "112"
username sfx12 phonenumber "204"
username SFXSC phonenumber "110"
username sfx16 phonenumber "132"
username sfx4 phonenumber "105"
username SFX phonenumber "108"
username sfx3 phonenumber "103"
username sfx5 phonenumber "107"
username sfx10 phonenumber "202"
username sfx6 phonenumber "109"
username sfx9 phonenumber "201"
username sfx8 phonenumber "200"
username sfx14 phonenumber "130"
username sfx2 phonenumber "101"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 4
script "aa.aef"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "dialByExtnAnytimeInputLength" "3"
parameter "operExtn" "100"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "true"
parameter "dialByFirstName" "true"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "true"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "1"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 10
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "A801"
parameter "strMWI_ON_DN" "A800"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 10
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 10
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-192-168-2-252"
end reporting
ccn subsystem email
end subsystem
ccn subsystem fax
end subsystem
ccn subsystem sip
gateway address "192.168.2.253"
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 400
application "autoattendant"
enabled
locale "fr_FR"
maxsessions 4
end trigger
ccn trigger sip phonenumber 800
application "voicemail"
enabled
locale "fr_FR"
maxsessions 5
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail notification enable
voicemail notification allow-login
voicemail broadcast mwi
voicemail callerid
voicemail default mailboxsize 3600
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail live-record beep duration 0
voicemail mailbox owner "SFX" size 3600
end mailbox
voicemail mailbox owner "sfx10" size 3600
end mailbox
voicemail mailbox owner "sfx11" size 3600
end mailbox
voicemail mailbox owner "sfx12" size 3600
end mailbox
voicemail mailbox owner "sfx13" size 3600
end mailbox
end
for the license i juste intall a license for 5 mailbox for test
SFXISR01#service-module ism 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 67
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 8.6.4
CUE Running on ISM
Module resource information:
  CPU Frequency: 1068 MHz
  Memory Size: 493 MB
  Disk 0 Size: 4110 MB
No install/uninstall in progress
No local partition
Unfortunattely all looks ok
Did you reload the cue?
service-module ism 0/0 reload
yes i reload and the same problem
Two questions
1)  the voicemail is working?
2) did you configure aa script?
chrysostomos
the script configured but the voicemail notworking
So the cue is not running properly
Did you perform the initial installation of cue?or you have done it from cli
May you have to reinstall the cue application if the initial installation has been done seccesfully
cc
the initial installation of CUE from Cli
send pls the
show ccn subsystem sip
Also r you sure that you have all the appropriates licenses for aa and voicemail?
