CUE Blank
kashif2401
Hi everybody,
Im using a brand new 2901 Router, and installed a new ISM-SRE-300-k9 hardware onto it.
I gave all the basic commands for ISM 0/0 along with the route.
interface ISM0/0
ip unnumbered Loopback0
service-module fail-open
service-module ip address 1.1.1.2 255.255.255.0
service-module ip default-gateway 1.1.1.1
ip route 1.1.1.2 255.255.255.255 ism 0/0
But the ISM 0/0 came blank, without any software on it.
So I downloaded a ZIP file, (also separate files), put in FTP (also TFTP)
I used different methods:
1. service-module ism 0/0 install url ftp://cisco:cisco@10.1.1.2/cue/cue-vm-k9.SPA.sme.8.6.12.pkg
2. service-module ism 0/0 install url ftp://cisco:cisco@10.1.1.2/cue/cue-vm-k9.SPA.sme.8.6.12.pkg script cue-vm-k9.SPA.sme.8.6.12.pkg.install.sre
For above methods i got this error:
Proceed with installation? [no]: yes
%Error: Couldn't open ftp://*****:*****@10.1.1.2/cue/cue-vm-k9.SPA.sme.8.6.12.pkg.install.sre
Execution of script cue-vm-k9.SPA.sme.8.6.12.pkg.install.sre failed, installation aborted
NSA#
*Nov 21 15:17:55.207: %SM_INSTALL-3-INST_SCRIPT_FAIL: Execution of script cue-vm -k9.SPA.sme.8.6.12.pkg.install.sre failed, installation aborted
The file which its looking is already there in that folder.
Other Method:
Pressed ***
config
ServicesEngine boot-loader> config
IP Address [1.1.1.2] >
Subnet mask [255.255.255.0] >
TFTP server [10.1.1.2] >
Gateway [1.1.1.1] >
<A.sme.8.6.12
Default Boot [none|disk] [disk] >disk
Default bootloader [primary|secondary] [primary] >primary
Updating flash with bootloader configuration.
Please wait .............. done.
ServicesEngine boot-loader> boot helper
Loading tftp://10.1.1.2/cue-installer.SPA.sme.8.6.12 ... done.
Verifying ...
Corrupted netboot image detected
done.
Starting Kernel.
Help me in solving this issue..
I have gone through many other cases on supportforum, but none could help me
Is there any fault in the hardware? do we to need to RMA this
Or am  I missing a simplest of thing?
Semih Tigli
hi ,
did you solve it ? I have same problem.
Paul Norris
Try this once you are on the console of the CUE. Make sure you change the package for the version you have.
Works like a charm.
# software install clean url ftp://192.168.10.11/cue-vm-k9.uc560.7.1.3.pkg username cisco password cisco123456
I can not login to cue service engine mode. I am in  ServicesEngine boot-loader mode.
SC-CME#service-module isM 0/0 session
Trying 142.100.66.254, 2067 ... Open
Time-out from RBIP response wait loop
SRE installation step 2 failed
SRE installation failed - Recovery now...
Installation failed, restore orignial configuration...
ServicesEngine Bootloader Version : 2.1.18
ServicesEngine boot-loader> ?
