Hi Celine,
Database Purge deletes the call stats from the database, you can select a date and it will delete all records older than the date selected and delete them. It will help reduce the size of the database, so no need to do it only if TAC recommends it. As a best practice, you should run it after business hours and it should not affect the consoles, but depends on how much data you have.
Tere.
If you find this post helpful, please rate!
Tere.
If you find this post helpful, please rate! :)
