06-15-2013 02:23 PM - edited 03-16-2019 05:54 PM
Dears,
During post installtion i gave admin username and password for AXL user, now I want to change a AXL username in CUP, when i try to change through the Systems>CUCM Publisher It gives me the error "Error: [4092] Failed to verify if the CUCM and IM and Presence Service versions match"
Can anybody help me with any trick to change this.
Solved! Go to Solution.
06-22-2013 02:49 AM
Jack, yes this is the file you will need for the upgrade. You will use the install/upgrade on the platform admin page.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-22-2013 03:02 AM
Hi Jack,
The file you have is right. If the bug states that it is fixed on this version, go ahead with the upgrade.
06-15-2013 03:28 PM
06-16-2013 12:58 PM
06-16-2013 10:54 PM
Dears,
Can anybody help me for the above query please.
06-17-2013 01:58 PM
Nobody can answer me or is it i am asking something funny,
There are 2 ways for fixing this BUG either upgrade to 9.1(1.21001.1) OR according to the link provided above which i have to run the linux commands which are unknown for me.
According to the link the BUG is fixed in 9.1(1.21001.1) , Can anybody route me to this file in cisco website i have a support contract i can download.
06-17-2013 02:33 PM
Jack,
It looks like that file is not available from CCO. YOu ay need to open a TAC case to get that file. The latest file on CCO is
UCSInstall_CUP_9.1.1.20000-5.sgn.iso
06-21-2013 02:43 PM
Dear
The file mentioned above in the link can be downloaded BUT i think the file is full CUP 9.1.1.20000-5 it is not just a upgrade file from 9.1.1.10000-8 previous version.
I should go ahead to install ???, I hope it i will not crash my existing system.
06-22-2013 01:44 AM
Hi Jack,
The version you are lookin for is an ES. Please proceed with opening a TAC SR and they will publish it across.
If it is fixed in 9-1-1-20000-5, please proceed with upgrading to that from the cisco site.
06-22-2013 02:33 AM
Hello Avinash,
what do you mean by ES ???
I have downloded the file UCSInstall_CUP_9.1.1.20000-5.sgn.iso from cisco website becz i have a 3 year special support ,,means any version launches in the market i have privilege to upgrade.
06-22-2013 03:02 AM
Hi Jack,
02-07-2015 05:03 PM
Just fixed my problem with TAC. All they did was change the Password on AXL User in CUCM, and the password for the AXL user in CUCM IM and Presence.
I thought it was a good idea to post this workaround, since I couldn't find it anywhere. The version of my CUCM IM and P is 9.1.1.41900-1
Simple solution for a reported bug... WOW.
06-22-2013 02:49 AM
06-22-2013 03:14 AM
Hello Avinash,
In your previous reply u have mentioned ES what do you mean by ES.
06-22-2013 03:17 AM
ES is a special version for a bug fix. It is not provided on cisco site and if you are hitting a specific bug, TAC can provide it across to address that issue specifically.
