02-06-2008 11:59 AM - edited 03-15-2019 08:40 AM
I want to add an application server in CCM 6.0, but all i see as choices when i want to add CUP, is Cisco Unity and EPAS !!
Is EAPS the same as CUP ? plz help
Solved! Go to Solution.
02-07-2008 01:59 AM
I spent hours doing the same thing, the APP_SERVER_EPAS selection is actually the presence server,
but it must be that the selection field has encoding problems, you will also see this on other pages of configs, I have no idea what the problem is.
02-07-2008 02:33 AM
Yes, presence 6.0 is linux based, easy install,
the integration with callmanager is not straightforward.
02-07-2008 10:07 PM
you can see here that the OS is linux for CUPS 6
02-06-2008 05:07 PM
You should have 3 options
Unity
Unity connection
CUPS
If you are not seeing these add english language to your browser
02-07-2008 12:14 AM
I have also got this problem, I then used Firefox browser and the problem went away. After rebooting the server the problem then appeared in Firefox, it has affected a lot of the fields in CUCM6.
02-07-2008 12:57 AM
I have changed to firefox English and the problem still percists !!
In fact when i want to add a new application server on the CCM 6, in the "Application Server Type" field all i have is 3 choices:
-TypeAppServer.APP_SERVER_UNITY_4_X
-TypeAppServer.APP_SERVER_UNITY_1_X
-TypeAppServer.APP_SERVER_EPAS
I don't think it's a problem of browser!
Plz help.
Thnaks
02-07-2008 01:03 AM
As I said, in prev message, it isn't the browser as both browsers develop the problem!
currently to get around it i chose the
APP_SERVER_EPAS option and that works. My prev message was simply to convey that I also have noticed the problem, and that It looks like a widespread issue.
02-07-2008 01:44 AM
Thx a lot for ur respond. i appreciate this.
So as i understood, all i have to do is to chose
APP_SERVER_EPAS as application server? and it should work?
It's really Bizarr, because in cisco documentation it's said to chose Cisco Unified Presence Server in the 'Application Server" field! but we don't find such choice , instead we find APP_SERVER_EPAS !!
thank you
02-07-2008 01:59 AM
02-07-2008 02:30 AM
Thx a lot for your help , i appreciate this.
I have another question that i hope you could help me with.
In fact i was wondering if CPS 6.0 is a based on linux as it's the way for CCM 6.0 ?
Thx.
02-07-2008 02:33 AM
02-07-2008 03:40 AM
Hi again, u'r really helping me !! Thx,
I wondered also, if u could help me again , this once i have a 7911 phone and i want it to work with SIP, so as i understood i have to download a SIP image and upload it to the phone.
Is it true? and if it's from where exactely to download such image from cisco site,and which step do i need to do ?
Thx alot.
02-07-2008 06:26 AM
hi again ;)
Where could i find in the net or in the cisco site that presence 6 is linux based?
Thx again
02-07-2008 10:07 PM
02-08-2008 12:46 AM
thx for ur respond
