CUPS + MOC: SIP userID & Callmanager userID
Finnaly after ordering michael's book we are able to implement CUPS and MOC 2007. (including call control)
The problem is, to get the phone system integration active, I had to change my SIP userID (m.bastinck) to my cisco callmanager user id (numbers only). I prefer to keep my old SIP userID but it's impossible to use this sign-in name for extension mobility.
Is there a way i can keep my cisco user id (numbers only) and SIP userID (m.bastinck)
ivillegas
Level 6
Level 6
If you are running CUPS 6.0.3 or later, and CallManager 6.1.2 or later, you should be able to get the RCC(Remote Call Control) feature to work, while using different formats for OCS SIP ID and CallManager IDs. With previous versions, these two IDs would have to have the same format for the RCC feature to work as you wish.
