Custom Access Control group for Users Page
sherif.elella
I want to create an access control group to allow users to access their user webpage and change their PIN ONLY!
I copied standard CCM enduser group, and removed standard CCM Admin User, and created a copy of that role and removed all updates from it except the one for user settings.. but I can still change everything else other than the PIN.
documentation clearly says
Standard CCM End Users
Cisco Unified CM User Options
Grant an end user log-in rights to the Cisco Unified CM User Options
Tip After you configure the user, make sure that you add the user to the Standard CCM End Users user group (User Management > User Group). If you do not add the user to this group, the user cannot view and update the Cisco Unified CM User Options.
Standard CCMUSER Administration
Allows access to the Cisco Unified CM User Options.
what am I missing?
Rob Huffman
Hi there,
In addition to the excellent info from Java & Mohammed (+5) I believe the only way to restrict access to certain settings on the ccmuser page is via the control level set via>Enterprise parameters>User Options Parameters;
Enterprise Parameters—Administrators can set enterprise parameters in Cisco Unified Communications Manager Administration to determine which user options are available for users to configure. For example, administrators can configure Cisco Unified CM User Options to remove all call forwarding options. Enterprise parameters are set by system administrators in Cisco Unified Communications Manager Administration. They appear in the Enterprise Parameters Configuration window, under User Options Parameters.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/useroptions/9_0_1/CUCM_BK_CA32DEF9_00_cucm-user-options-guide-90/CUCM_BK_CA32DEF9_00_cisco-unified-communications-manager-user_chapter_00.html
Cheers!
Rob
I don't think you can limit users within users page. If you give them access to user settings then they can change all the settings in the user page.
Jaime Valencia
The granularity for the permissions in CUCM only goes as far as level page, if you have access to a certain config page, you can change any setting in that page, and for all the items that might exists.
There is no way to configure a user that can only change the PIN.
You can configure self-care portal and leave each user change their own PIN as they require.
java
if this helps, please rate
Rob Huffman
Hi there,
Cheers!
Rob
hi there!!
thanks alot, this is what i was looking for. its kinda odd that they'd do this way, ud think the roles read/update should be enough.
