Custom tab in RTMT
Murali Dharan
Hello All,
I didnt get proper doc for this. Why we have Custom tab in RTMT tool (Check attachment), is that to configure new alerts apart from predefined alerts in RTMT. If yes, please let me know how to add new alerts in RTMT under custom tab.
-Murali
Murali Dharan
I got it. We have to use perfomance option in RTMT to add alerts under custom .
Murali
Hi Murali
Please find the below information :-
1. Go to System--> Performance--> Open Performance Monitoring
2. Find the device type you want to configure the alert to and expand it. You'll need to select a single counter instance to show in the right pane.
3. Right click on it and select "counter monitoring"
4. Right click on the chart and select "Set Alert/Properties"
5. Select the "Enable Alert" checkbox and configure the parameters needed.
6. You will be able to view the alert on the Alert's Custom tab.
Thank you
Please rate all useful information
