ā07-01-2025 12:38 AM
Anyone now what is the correct TFTP format to upload a customised background photo on 8841/8851 MPP phones using the control hub?
Solved! Go to Solution.
ā07-01-2025 08:22 AM
Hi Michalis,
sorry, I am still used to do this on CUCM but on Webex Control Hub it's even easier:
HTH!
ā07-01-2025 02:38 AM
Hello @Michalis Papasavva,
your images must be in PNG format and the full sized image must be within the following dimensions for the 8800 series phones:
If you want the user to be able to select your image from various wallpapers available on the phone, then you also need to modify the List.xml file. This is not needed if you want to push the image to the phone using a Common Phone Profile.
Then upload the images, the thumbnails, and - if needed - the List.xml file to your TFTP server to the following directory:
Finally, once the files are uploaded, you need to restart the TFTP server(s).
Further details like image dimensions for Key Extension Modules can be found here.
HTH!
ā07-01-2025 07:32 AM
Hi Jens,
I believe you descripted the procedure for phones registered on CUCM, i am asking how to do it on a phone registered on control hub. (webex calling)
Hi Michalis,
HTH!
ā07-15-2025 06:58 AM
Hi Jens,
Sorry for late reply, is working thanks
