Database activity in RTMT
Gordon Ross
Level 9
Level 9
Since we upgraded from 8.0.2 to 8.0.3(SU2), we've noticed that RTMT is showing a lot more database activity ("Change Notification Requests Queued in DB") than before.
Has anyone else seen this ? CUCM appears to be working OK.
I'm half wondering if it's more a thing with RTMT changing how it counts these values.
GTG
Please rate all helpful posts.
5 Replies 5
Jaime Valencia
Queue Delay
This counter provides the number of seconds that the change notification  process has messages to process but is not processing them. This  condition is true if:
either Change Notification  Requests Queued in Database (QueuedRequestsInDB) and Change Notification  Requests Queued in Memory (QueuedRequestsInMemory) are non-zero, or
QueuedRequestsInDB
This counter represents the number of change notification records that  are in the DBCNQueue (Database Change Notification Queue) table via  direct TCP/IP connection (not queued in shared memory). This counter  refreshes every 15 seconds.
This counter represents the number of change notification requests that  are queued in shared memory.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
So what does it mean what those figures go negative ?
tobin hawkshaw
Bonjour mon ami
It may also be worth mentioning that this is a full sip installation. havn't got an answer for you but as long as they are not timing out then I would guess they have changed a timer or something between versions, your not using any new functionality on this version are you? presence or something similar?, or perhaps you have more services started than previously?
As I said: We've only moved from 8.0.2 to 8.0.3(SU2) - not a massive leap in versions. Certainly in the 72-hours since we've upgraded, I haven't rolled out any new features.
GTG
Gordon Ross
Level 9
Level 9
Finally found the root cause: Tomcat.
Had to restart Tomcat ('cause it was grinding to a halt, eating two cores of CPU useage)
After restarting it (it took a while to settle down, as Tomcat always does) DB activity & CPU useage dropped back to normal.
