Database password recovery
Scott Hanson
Level 3
Level 3
All,
In CUCM 8.x is there a way to recovery the database password if it has been lost?
Thanks.  I always rate replies!
Jaime Valencia
There is no DB pwd, there's an app pwd (ccmadmin/serviceability), a platform pwd (CLI/OS admin) and a security pwd (used for SUB installs and other apps integration)
Which one are you referring to?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks.  Security
set password user
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_5_1/cli_ref_851.html#wp156897
No way to recover it, but you can change it. See above link
java
java
