11-04-2010 12:30 PM - edited 03-16-2019 01:44 AM
I'm hopin someone can give me a hand as we've banged our head against the wall a few times now after attempting the DC Manager regedit/password recreate procedure 4 or 5 times with no success. We're working on a CM 4.2 server and just aren't having any luck. Can anyone out there decrypt for me?
Solved! Go to Solution.
11-04-2010 12:33 PM - last edited on 02-18-2019 08:41 PM by Gagandeep Kaur
Please send me a private message or e-mail with a screenshot of the encrypted password.
11-04-2010 02:11 PM
Sent you a private message, does that work or do you need something else? Thanks.
04-07-2011 06:24 AM
Also if you are looking at a way of acquiring the passwords / pins information for the upgrade of CCM4 to something bigger its probably worth having a look at dominocomms.com, they have an applicaiton available that can help (saved our upgrade about 20 mans days so well worth it)
