08-14-2017 01:56 AM - edited 03-17-2019 11:00 AM
Ä customer is trying to call numbers to ukrain, but all the calls are failing.
When I debug in the mgcp gateway I i'm getting"a " Cause i = 0x8283 - No route to destination "
When the customers calls to other countrys it works fine.
Seems it only happens when they call numbers to ukrain.
dialed number analyzer is saying that it should route this pattern.
I'm a little bit lost now
08-14-2017 02:18 AM
Can you provide the full debug for a call from the router.
debug isdn q931
debug MGCP packet
JB
08-14-2017 02:55 AM
I have checked with the customer again.
Now it seems that they are not able to call numbers in the area code of Kiev (oekrain)
Other numbers in oekrain are working.
so that means numbers in this range 000.38 (44) are not routing out of the GW.
It hits the GW, but not getting out.
however I have attached the packet of the calls that's works and not.
08-14-2017 03:18 AM
I see the disconnect coming from service provider.
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0080
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '2200670'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0442300700'
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8080
*Aug 14 17:03:41: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8080
Progress Ind i = 0x8288 - In-band info or appropriate now available
Which means either its a provider issue, or you are not sending the number in correct format to ISP. Do you think you are sending the correct format for number your ISP is expecting. If you are not sure you need to call them and they can tell you how they would like to receive the number.
(Rate if it helps)
JB
08-14-2017 03:44 AM
Hi JB,
According to the customer all the other area codes to Ukrain works fine.
Except (044) they get no exsist tone.
08-14-2017 03:49 AM
Can you attach the above debugs for a working call.
JB
08-14-2017 04:47 AM
08-14-2017 05:09 AM
I think this is a service provider issue as i dont see lot of difference in working and non-working debugs. But in the non-working we receive disconnect from service provide, have you asked your service provider about this, bu showing thim this debug?
(Rate if it helps)
JB
08-14-2017 06:40 AM
I gave the customer ( a client of us) advise to contact the SP.
Because we don't have contact with the SP.
I'm curious what they say.
However i'm thanking you with the extra thinking!
If there is new information I will update you
