default route pattern
Is it possible to make a default route pattern on the Call manager that acts like a default route in networking? So if the Call manager gets a Call to a number that does not match a specific route pattern
the Call manager Can direct that call over a certain SIP-trunk or gateway.
Call manager version is 7.0.something
Thomas
Aaron Harrison
Sure - you can use a wildcard mask for this, but generally routing 'everything' is going to be a bad idea as you are going to be sending lots of rubbish to the gateways (e.g. misdialled numbers etc).
You could for example send any number starting with 9 by using a 9! route pattern. Rinse/repeat for all the other 'first' digits.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
