default Xml file structure for 7800 phones with cme 10.5
Dears,
am facing a problem with Cisco Ip phone 7800 and am trying to upgrade the phones through my laptop(as a tftp server )
the questions is what is structure for the default sip xml file ?
best regards
Hi Amer Mohammad A...,
 check this link: Generating Configuration Files for Phones, pg 8 - Step 3 (SIPDefault.cnf).
Hope this helps.
thanks for your help
You are welcome.
I hope I have helped you ... I will consider this matter resolved.
Regards.
