Delete MGCP config
gvindio
Hello Community,
I have a Cisco ISR 4431 and it looks like it was used for Telephony gateway.  I want to use it for an ISP and my question is how do I delete the MGCP profile it has on its running config.
EXAMPLE:
version 15.4
no platform punt-keepalive disable-kernel-core
hostname
!no aaa new-model
subscriber templating
redundancy
mode none
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
The configuration as such won't affect anything and if I'm not wrong it is automagically added to the configuration if the router is licensed with voice functionality. If you truly want to get rid of it you would need to change the license on the router I believe.
Response Signature
Jaime Valencia
You simply remove the configuration, that's it.
java
if this helps, please rate
I’ve tried that and the MGCP profile keeps coming up. I even tried to delete the MGCP profile default and router reply’s I can’t.
Response Signature
