Hi, Im trying to give DHCP to VOIP Phones, things work perfectly till i add more than 1 phone to each VLAN, then i get DHCP Conflicts at my Telephony router, wich gives DHCP to the Phones, then they enter a loop where they try to get an IP and a CM list number. Some phones pick up their line perfectly, but others enter that loop, i tried clearing the conflict but it doesnt work, i search in this forums and they recomend clearing the conflicts or adding a command to eleminate this conflict logs, but or they dont work or they simply dont exist as a command in the router, im new at telephony so i dont know what to do about this loop of DHCP and CM List.
I leave my pka so you can check every configuration so you can tell what im doing wrong with my dhcp or telephony service (TELEFONICA).
