dial peer failover with two SIP server problem
Yazen Alaa
Dear All
I have two sip servers(primary , backup) , and cisco 2900 voice gateway , the problem is
when the primary server goes down , when the backup server goes up for redaundancy ,  All sip phones get not working and give me but i can make ping to the backup server  , when the primary return up all sip phones become working fine , what is the missing in the configuration ??? and how to solve this problem ????
please see the configuration below:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
sip-ua
retry invite 2
timers trying 150
description ABK-HO-Connection
ip address 12.103.115.137 255.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 12.103.105.254
control-plane
voice-port 0/0/0:15
connection plar 1890890
voice-port 0/1/0:15
voice-port 0/0/1:15
voice-port 0/1/1:15
dial-peer voice 10 pots
destination-pattern 9
port 0/0/0:15
dial-peer voice 11 pots
preference 1
port 0/0/1:15
dial-peer voice 1 voip
destination-pattern 1890890
session protocol sipv2
session transport udp
session target ipv4:12.103.115.133:8060
dtmf-relay rtp-nte
codec g711ulaw
fax-relay ecm disable
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
dial-peer voice 2 voip
preference 1
session target ipv4:12.103.115.134:8060
dtmf-relay rtp-nte
codec g711ulaw
fax rate 14400
no vad
gateway
media-inactivity-criteria all
timer receive-rtcp 5
timer receive-rtp 1200
sip-ua
gatekeeper
shutdown
9 Replies 9
radoslav-drabik
if the primary server goes down (SIP stuck is down) and you can still ping it you can implement the SIP option keep alive feature to determine that.
voice-class sip options-keepalive
The other side of the connection must support it, though. The gateway will send SIP options messages to monitor if the destination is still alive.
You can tune the timers as well:
dial-peer voice 100 voip
  voice-class sip options-keepalive up-interval 12 down-interval 65 retry 3
Here is some documentation:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_v2.html#wp1272954
Hi radoslav
first of all , thanks for ur reply
to add this commands , i need to create new dial-peer as mention above  , or this global commad ???
Assume that after adding this commands , and the problem is still not solved , do have another soution or double work for that  ???? , becasue i have to turn of the sip  primary server today  at mid night to test the backup sip server and i have down time only one hour to solve this issue
thanks and regards
Hi Radoslav
please feed me back ASAP
I am waiting your updates
thanks
just add these lines under the dial-peer for the primary and secondary server and it should be fine.
Anyway, without this command, the router will try the first server and then it will try the second one. But without options-keepalive the failover might take longer. Options keepalive activaly monitors the destination and busyout the dial-peer if the destination is not reachable.
sip-ua
retry invite 2  -> 2 Invites, if it fails it tries the second dial-peer.
Hi Radoslav
I did add these commands , but still the same problem ,  then i did open ticket with cisco , we found that the problem from Sip  server is not resoponding
thanks so much for supporting
Hi Radoslav
sorry for bothering you again , in actually the customer did check with ININ sip server support and they said dont have ant troubles in SIP servers and the problem from voice gateway , now i have confused , cisco said the problem from ININ server and ININ said the problem from voice gateway, what you think the problem , did you face like this problem before ???  , see below the last configuration and debug :
voice service voip
sip
license udi pid CISCO2901/K9 sn FGL152723QM
hw-module pvdm 0/0
username icadmin secret 5 $1$7AMW$EP19aUZuccUF3u8lEFuQZ.
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
controller E1 0/1/0
controller E1 0/1/1
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
ip http server
snmp-server community abk@8kro RO
control-plane
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/0/1:15
voice-port 0/1/1:15
port 0/0/0:15
preference 1
port 0/0/1:15
voice-class sip options-keepalive up-interval 12 down-interval 65 retry 1
dtmf-relay rtp-nte
codec g711ulaw
fax rate 14400
no vad
preference 2
session target ipv4:43.103.103.242:8060
dtmf-relay rtp-nte
codec g711ulaw
fax rate 14400
no vad
gateway
sip-ua
retry invite 2
timers trying 200
gatekeeper
shutdown
Nov 23 02:15:50.080:  vsacount in free is 1
Nov  23 02:15:50.080: //5227327/889C8894AD39/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Nov 23 02:15:50.080: //5227327/889C8894AD39/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Nov 23 02:15:50.132: //5227327/889C8894AD39/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29DF9334,exit Tag=0x0, Call Id=5227327,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov 23 02:15:50.132: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:15:50.132: :cc_free_feature_vsa freeing 31BA8AD8
Nov 23 02:15:50.132:  vsacount in free is 0
Nov 23 02:16:01.644: //-1/8FA03029AD3A/CCAPI/c
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#c_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=67060870
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_tim
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#eout =0
Nov 23 02:16:01.644: //-1/8FA03029AD3A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x29DF9334, Call Info(
   Calling Number=67060870,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1890890(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Rundeoute Label=, CLID Transparent=FALSE), Call Id=-1
Nov 23 02:16:01.644: //-1/8FA03029AD3A/CCAPI/ccCheckClipClir:
   In: Calling Number=67060870(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=67060870(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Nov 23 02:16:01.644: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:01.644: :cc_get_feature_vsa malloc success
ABK_CCVoiceGateway#undebug a
Nov 23 02:16:01.644:  cc_get_feature_vsa count is 1
Nov 23 02:16:01.644: :FEATURE_VSA attributes are: feature_name:0,feature_time:834308832,feature_id:4895384
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=67060870(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Alll
All possible debugging has been turned off
ABK_CCVoiceGateway#lowed),
   Called Number=1890890(TON=Unknown, NPI=Unknown))
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/cc_process_call_setup_ind:
   Event=0x31379178
Nov 23 02:16:01.644: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1890890
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/ccCallSetContext:
   Context=0x31AB674C
   >>>>CCAPI handed cid 5227329 with tag 10 to app "_ManagedA
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#ppProcess_Default"
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/ccCallProceeding:
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2, Params=0x302C5AD0, Progress Indication=NULL(0)
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/ccCheckClipClir:
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#5227329/8FA03029AD3A/CCAPI/ccCheckClipClir:
   Destination Pattern=1890890, Called Number=1890890, Digit Strip=FALSE
   Calling Number=67060870(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=8FA03029-344A-11E2-AD3A-30E4DB632720, Outgoing Dial-peer=2
Nov 23 02:16:01.644: //5227329/8FA03029AD3A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=67060870
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   hunt_group_timeout =0
Nov 23 02:16:01.648: //5227329/8FA03029AD3A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29680440, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=67060870,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1890890(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov 23 02:16:01.648: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:01.648: :cc_get_feature_vsa malloc success
Nov 23 02:16:01.648:  cc_get_feature_vsa count is 2
Nov 23 02:16:01.648: :FEATURE_VSA attributes are: feature_name:0,feature_time:834308608,feature_id:4895385
Nov 23 02:16:01.648: //5227330/8FA03029AD3A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Nov 23 02:16:01.648: //5227330/8FA03029AD3A/CCAPI/ccCallSetContext:
   Context=0x302C5A80
Nov 23 02:16:01.648: //5227329/8FA03029AD3A/CCAPI/ccSaveDialpeerTag:
Nov 23 02:16:01.648: //5227330/8FA03029AD3A/CCAPI/cc_api_call_proceeding:
   Interface=0x29680440, Progress Indication=NULL(0)
Nov 23 02:16:02.012: //5227330/8FA03029AD3A/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x29680440, Call Id=5227330
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Nov 23 02:16:02.012: //5227329/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Nov 23 02:16:02.012: //5227330/8FA03029AD3A/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=5227330
Nov 23 02:16:02.012: //5227330/8FA03029AD3A/CCAPI/ccCallDisconnect:
Nov 23 02:16:02.012: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:16:02.012:  vsacount in free is 1
Nov 23 02:16:02.012: //5227329/8FA03029AD3A/CCAPI/ccCallDisconnect:
Nov 23 02:16:02.012: //5227329/8FA03029AD3A/CCAPI/cc_api_get_transfer_info:
Nov 23 02:16:02.632: //5227329/8FA03029AD3A/CCAPI/cc_api_call_disconnect_done:
Nov 23 02:16:23.240: //-1/9C7F7B0DAD3B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=69602498
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 23 02:16:23.240: //-1/9C7F7B0DAD3B/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=69602498,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov 23 02:16:23.240: //-1/9C7F7B0DAD3B/CCAPI/ccCheckClipClir:
   In: Calling Number=69602498(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=69602498(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Nov 23 02:16:23.240: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:23.240: :cc_get_feature_vsa malloc success
Nov 23 02:16:23.240:  cc_get_feature_vsa count is 1
Nov 23 02:16:23.240: :FEATURE_VSA attributes are: feature_name:0,feature_time:834308832,feature_id:4895386
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=69602498(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/cc_process_call_setup_ind:
   Event=0x31379178
Nov 23 02:16:23.240: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/ccCallSetContext:
   Context=0x31ABC674
   >>>>CCAPI handed cid 5227331 with tag 10 to app "_ManagedAppProcess_Default"
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/ccCallProceeding:
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x2A584D7C, Progress Indication=NULL(0)
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/ccCheckClipClir:
   Guid=9C7F7B0D-344A-11E2-AD3B-30E4DB632720, Outgoing Dial-peer=2
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=69602498
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 23 02:16:23.240: //5227331/9C7F7B0DAD3B/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=69602498,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Nov 23 02:16:23.244: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:23.244: :cc_get_feature_vsa malloc success
Nov 23 02:16:23.244:  cc_get_feature_vsa count is 2
Nov 23 02:16:23.244: :FEATURE_VSA attributes are: feature_name:0,feature_time:834308608,feature_id:4895387
Nov 23 02:16:23.244: //5227332/9C7F7B0DAD3B/CCAPI/ccIFCallSetupRequestPrivate:
Nov 23 02:16:23.244: //5227332/9C7F7B0DAD3B/CCAPI/ccCallSetContext:
   Context=0x2A584D2C
Nov 23 02:16:23.244: //5227331/9C7F7B0DAD3B/CCAPI/ccSaveDialpeerTag:
Nov 23 02:16:23.244: //5227332/9C7F7B0DAD3B/CCAPI/cc_api_call_proceeding:
Nov 23 02:16:23.444: //5227332/9C7F7B0DAD3B/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x29680440, Call Id=5227332
Nov 23 02:16:23.444: //5227331/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Nov 23 02:16:23.444: //5227332/9C7F7B0DAD3B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=5227332
Nov 23 02:16:23.444: //5227332/9C7F7B0DAD3B/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Nov 23 02:16:23.444: //5227332/9C7F7B0DAD3B/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x29680440, Tag=0x0, Call Id=5227332,
Nov 23 02:16:23.444: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:16:23.444: :cc_free_feature_vsa freeing 31BA89F8
Nov 23 02:16:23.444:  vsacount in free is 1
Nov 23 02:16:23.444: //5227331/9C7F7B0DAD3B/CCAPI/ccCallDisconnect:
Nov 23 02:16:23.444: //5227331/9C7F7B0DAD3B/CCAPI/cc_api_get_transfer_info:
Nov 23 02:16:23.496: //5227331/9C7F7B0DAD3B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29DF9334, Tag=0x0, Call Id=5227331,
Nov 23 02:16:23.496: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:16:23.496: :cc_free_feature_vsa freeing 31BA8AD8
Nov 23 02:16:23.496:  vsacount in free is 0
Nov 23 02:16:45.224: //-1/A999F8D5AD3C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=67060870
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 23 02:16:45.224: //-1/A999F8D5AD3C/CCAPI/cc_api_call_setup_ind_common:
Nov 23 02:16:45.224: //-1/A999F8D5AD3C/CCAPI/ccCheckClipClir:
Nov 23 02:16:45.224: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:45.224: :cc_get_feature_vsa malloc success
Nov 23 02:16:45.224:  cc_get_feature_vsa count is 1
Nov 23 02:16:45.224: :FEATURE_VSA attributes are: feature_name:0,feature_time:811055800,feature_id:4895388
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=67060870(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/cc_process_call_setup_ind:
   Event=0x31379178
Nov 23 02:16:45.224: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/ccCallSetContext:
   Context=0x302C9398
   >>>>CCAPI handed cid 5227333 with tag 10 to app "_ManagedAppProcess_Default"
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/ccCallProceeding:
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x2A56E3E4, Progress Indication=NULL(0)
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/ccCheckClipClir:
   Guid=A999F8D5-344A-11E2-AD3C-30E4DB632720, Outgoing Dial-peer=2
Nov 23 02:16:45.224: //5227333/A999F8D5AD3C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=67060870
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1890890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 23 02:16:45.228: //5227333/A999F8D5AD3C/CCAPI/ccIFCallSetupRequestPrivate:
Nov 23 02:16:45.228: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 02:16:45.228: :cc_get_feature_vsa malloc success
Nov 23 02:16:45.228:  cc_get_feature_vsa count is 2
Nov 23 02:16:45.228: :FEATURE_VSA attributes are: feature_name:0,feature_time:811055576,feature_id:4895389
Nov 23 02:16:45.228: //5227334/A999F8D5AD3C/CCAPI/ccIFCallSetupRequestPrivate:
Nov 23 02:16:45.228: //5227334/A999F8D5AD3C/CCAPI/ccCallSetContext:
   Context=0x2A56E394
Nov 23 02:16:45.228: //5227333/A999F8D5AD3C/CCAPI/ccSaveDialpeerTag:
Nov 23 02:16:45.228: //5227334/A999F8D5AD3C/CCAPI/cc_api_call_proceeding:
Nov 23 02:16:45.428: //5227334/A999F8D5AD3C/CCAPI/cc_api
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#_call_disconnected:
   Cause Value=38, Interface=0x29680440, Call Id=5227334
Nov 23 02:16:45.428: //5227334/A999F8D5AD3C/CCAPI/cc_api_call_disconnected:
Nov 23 02:16:45.428: //5227333/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Nov 23 02:16:45.428: //5227334/A999F8D5AD3C/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=5227334
Nov 23 02:16:45.428: //5227334/A999F8D5AD3C/CCAPI/ccCallDisconnect:
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#
ABK_CCVoiceGateway#   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Nov 23 02:16:45.428: //5227334/A999F8D5AD3C/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x29680440, Tag=0x0, Call Id=5227334,
ABK_CCVoiceGateway#unisconnect_done:
Nov 23 02:16:45.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:16:45.428: :cc_free_feature_vsa freeing 3057B9D0
Nov 23 02:16:45.428:  vsacount in free is 1
Nov 23 02:16:45.428: //5227333/A999F8D5AD3C/CCAPI/ccCallDisconnect:
Nov 23 02:16:45.428: //5227333/A999F8D5AD3C/CCAPI/ccCalldebDisconnect:
Nov 23 02:16:45.428: //5227333/A999F8D5AD3C/CCAPI/cc_api_get_transfer_info:
Nov 23 02:16:45.480: //5227333/A999F8D5AD3C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29DF9334, Tag=0x0, Call Id=5227333,
ABK_CCVoiceGateway#undebug allent
Nov 23 02:16:45.480: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 02:16:45.480: :cc_free_feature_vsa freeing 3057BAB0
From the  logs, Cisco is right in that the call disconnect is coming from the far end, that is your provider side. The cause code is 38 which  means that  network is out of order.. The call was routed using the second dial-peer. So the failover is working.
Can you send a debug ccsip messages.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi aokanlawon
I escalated to another cisco engineer , and said chage the port from 8060 to 5060 and add this commads : session transport TCP to make it TCP not UDP then test.
In actually if i did as he said , how the dial-peer 1 voip is working  with port 8060???
do you think he is right ??
thanks
I didnt even see that in your config. May I ask why you are using port 8060. Sip uses port 5060. So yes the Cisco engineer is right. You can also change the transport mode to use TCP and see if it helps. But it is important to use port 5060. Did your provider instruct you to use port 8060?
