Dial Peer Show Dialed Number
Aquiles
i have a **bleep** 11.5  and when we use the dial peer to put an external call, whe number diales dowsnt show on the screen, and obvuously when we check the history calls now show  the number only the dial number to put an external call this is my configutation
telephony-service
video
max-ephones 58
max-dn 300
ip source-address 192.168.10.1 port 2000
auto assign 1 to 58
system message Cybersoft SA de CV
user-locale ES
network-locale ES
time-zone 9
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Mar 06 2019 09:06:02
dial-peer voice 1 pots
no tone dialtone remote-onhook
description ICEM
destination-pattern 9
no digit-strip
port 0/0/0
forward-digits 0
Dennis Mink
what is your full config, and what is the number you are trying to dial and where from?
also your pot dial peer has a pattern of 9, have you got other dial peers? can you do a sh dial peer voice summary?
Please remember to rate useful posts, by clicking on the stars below.
full config
Current configuration : 7197 bytes
! Last configuration change at 12:20:06 central Sat Mar 9 2019
version 15.6
hostname PBX
boot-start-marker
boot-end-marker
enable secret 5 $1$JzeF$Ef5akxDUuaU0k0MZt0BwF1
no aaa new-model
ethernet lmi ce
clock timezone central -6 0
clock summer-time central recurring
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.20.1 192.168.20.5
ip dhcp excluded-address 192.168.30.1 192.168.30.5
ip dhcp excluded-address 192.168.40.1 192.168.40.5
ip dhcp pool Data
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool Voice
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
option 150 ip 192.168.10.1
ip dhcp pool Video
network 192.168.30.0 255.255.255.192
default-router 192.168.30.1
ip dhcp pool Public
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-1347525897
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1347525897
revocation-check none
rsakeypair TP-self-signed-1347525897
crypto pki certificate chain TP-self-signed-1347525897
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31333437 35323538 3937301E 170D3138 30333033 31303530
33355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33343735
32353839 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C9BC FB1A637B 2B905202 37AD10FF 1EE436E8 47E6003D 40D2D3CA 31CB2EEB
C69A33B6 BAC3F097 635E7231 3C784298 15771FE4 997041E4 C535FF9E CFA00F66
8AF897C8 3B9AC978 68A71611 0EF2E03F F4A03AD0 0D496A3F C03FBAF1 D6AC732E
FA2569C2 3A9DED4E 7C1D9E16 ABD30CE5 2C9B9807 DEE6CF2E CD8FE6E2 92CA0348
61150203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14BF1C84 21BF315B BD685F43 A7413EB0 6D7018DC 56301D06
03551D0E 04160414 BF1C8421 BF315BBD 685F43A7 413EB06D 7018DC56 300D0609
2A864886 F70D0101 05050003 81810073 9D97710D 8FBEDC80 ADBB95F6 BB0C75EE
0CA9052D 07C26396 2F906159 A9C9F08D 60321B04 E1C35CCB 74252CFD CA923EF5
10EC0713 032C26CB 687E3D7F B1A73AB8 C820EC71 3812DB06 53BA1A7C 3904FE2B
CEA68DCC 81E274B3 E3F298F2 9F762AF1 0D251352 1EE20983 FF7220DE 808130F9
3B0CA5FF 94311941 0065A5AC AB1978
quit
voice-card 0
license udi pid CISCO2911/K9 sn FTX1523AH0Z
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
description Data
encapsulation dot1Q 1 native
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0.20
description Voice
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0.30
description Video
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
ip helper-address 192.168.10.1
ip nat inside
interface GigabitEthernet0/0.40
description Publica
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/1 overload
ip route 192.168.10.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.30.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.40.0 255.255.255.0 GigabitEthernet0/1
access-list 10 permit 192.168.10.0 0.0.0.255
access-list 10 permit 192.168.40.0 0.0.0.255
access-list 10 permit 192.168.30.0 0.0.0.255
control-plane
voice-port 0/0/0
connection plar 0449
caller-id enable
voice-port 0/0/1
connection plar 7902
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
description ICEM
no digit-strip
port 0/0/0
forward-digits 0
dial-peer voice 2 pots
description Cybersoft
destination-pattern 8
port 0/0/1
forward-digits all
gatekeeper
shutdown
telephony-service
video
max-ephones 58
max-dn 300
auto assign 1 to 58
user-locale ES
network-locale ES
time-zone 9
time-format 24
time-webedit
ephone-dn 1 dual-line
number 0449
label ICEM
name ICEM
ephone-dn 2 dual-line
number 7902
label Cybersoft
name Cybersoft
ephone-dn 3 dual-line
number 1001
label Rosa Maria Aguilar
name Rosa Maria Aguilar
ephone-dn 4 dual-line
number 1002
label Liliana Juarez Tapia
name Liliana Juarez Tapia
ephone-dn 5 dual-line
number 1003
label Recepcion
name Recepcion
ephone-dn 6 dual-line
number 1004
label Ing Aquiles Vera
name Ing Aquiles Vera
ephone-dn 7 dual-line
number 1005
label Soporte Tecnico
name Soporte Tecnico
ephone-dn 8 dual-line
number 1006
label Laboratorio
name Laboratorio
ephone-dn 9 dual-line
number 1009
label Cafeteria
name Cafeteria
ephone 1
mac-address DCA5.F43E.8A39
type 8945
missed-calls all
button 1:1 2:2 3:3 4:4
ephone 2
mac-address DCA5.F43E.8363
type 8945
missed-calls all
button 1:5
ephone 3
video
mac-address DCA5.F43E.86CB
type 8945
missed-calls all
button 1:7 2:2
ephone 4
video
mac-address DCA5.F43E.88C9
type 8945
missed-calls all
button 1:6
ephone 5
mac-address DCA5.F43E.849F
type 8945
missed-calls all
button 1:8
ephone 6
mac-address DCA5.F43E.8B33
type 8945
missed-calls all
button 1:4
ephone 7
mac-address 0007.7DDF.BD10
type 8941
button 1:9
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0
password cybersoft17
login
transport input telnet ssh
line vty 1 4
login
transport input none
scheduler allocate 20000 1000
ntp server time.google.com
end
