dial peer
sanjay.khurana
Hi ,
I have two site where uc540 is installed and site to site calling working fine ealier.
Now I m facing issue from site A I am not able to dial site B number , where Site B is able to dial Site A no.
when I dial 022012 ext from Site A to Site B getting unknown number.
following is config of Site A.
dial-peer voice 2101 voip
 corlist incoming call-internal
 description **CCA*INTERSITE outbound calls to Site B
 translation-profile outgoing multisiteOutbound
 destination-pattern 02....
 voice-class h323 1
 session target ipv4:192.168.2.1
 dtmf-relay h245-alphanumeric
 fax protocol cisco
 no vad
voice translation-profile multisiteOutbound
 translate calling 1114
voice translation-rule 1114
 rule 1 /\(^....$\)/ /01\1/
Site B.
 description **CCA*INTERSITE outbound calls to Site A
 voice-class h323 1
 fax protocol cisco
 no vad
Debug voip ccapi inout logs of Site A & Site B is attached.
pls help me where I am wrong.
Aaron Ratcliffe
If I'm reading correctly these are 2 different systems ? If so why is the session target for the dial pees the same IP ? Try change the session target of site A's dial peer to site B's systems IP address
