Dictionary cp7861 3PCC fw
info
I havn't found any dictionary for cp7861 with 3pcc fw. Can someone help me?
Not applicable
Do you mean a local address book?
If so then either select the Address Book PSK on the phone (looks like a book) :-) and add names to it using the phone UI.
The other solution is to go to the webpage of the phone:
http://ip_of_the_phone and go to the directory page. Here you can add/delete/change entries as well.
jeboer
Dictonary for different languages can be found here:
https://software.cisco.com/download/release.html?mdfid=284892535&flowid=46502&softwareid=282074288&release=12.0(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
go to the latest MPP firmware folder to download either the firmware or the dictionary/locale files.
If you are refering to directories then you could either use the Directory PSK (is the key that resembles a book) or go to the webpage of the phone:
http://ip_address_of_phone/ and select the dictionary tab.
