08-27-2012 12:50 AM - edited 03-16-2019 12:53 PM
We have implemented DID in our network. We are having 3845 gateway router and using H.323 as gateway protocol. Now the problem is when someone is calling from outside to a DID number the call is coming and caller id is visible but when a call is made from a DID number to outside (Mobile number) the call is going but the particular DID number is not showing in the cell phone instead the pilot number is showing and the problem is same for all the DID numbers configured in the network. So is there any configuration related issue??? Please suggest... The configuration that we made in the GW router for DID is follows -
controller E1 0/1/1
framing NO-CRC4
pri-group timeslots 1-31
description *** DID PRI ***
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 0/1/1:15
cptone IN
dial-peer voice 5 pots
description *** Outgoing calls to PSTN ***
preference 3
destination-pattern .T
no digit-strip
direct-inward-dial
port 0/1/1:15
forward-digits all
dial-peer voice 6 voip
destination-pattern 2213....
session target ipv4:XXX.XXX.XX.X
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
08-27-2012 06:41 AM
Hi Chrys,
I have applied the rule -
See the output
VOICE-GATEWAY#test voice translation-rule 15 3000004
Matched with rule 1
Original number: 3000004 Translated number: 2213004 --- > This is not what I want.
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
Still when I am dialing from DID number, pilot number is showing.
08-27-2012 06:44 AM
Hi Again
The translation rule is NOT correct.Because the last digits are not the same (extension and did)
My friend your dial plan is not very good
The extension must match the dids for easy managment
How many extensions do you have?
