DID on E1 PRI ISDN
Dear All,
I want to configure DID on E1 PRI
I configured the PRI as follows and I need help to configure the DID on it.
isdn switch-type < primary-net5 >
controller e1 0/2/0
framing <crc4>
linecode < hdb3 >
pri-group timeslots < 1-31 >
paolo bevilacqua
Have you ever configured voice before? Do you know about things like dial-peers, translation-rules, etc.?
Because if you don't, the best is that you engage a reputable professiona or UC certified Cisco partner for the job.
Yes, I know the dial-peer very well and I put the bellow configration of DID and didn't work
dial-peer voice 1 pots
corlist outgoing local-VM
description ** Inside Cairo **
destination-pattern 9[2-9].......
incoming called-number .
direct-inward-dial
port 0/2/0:15
forward-digits 8
Even I put connection plar 100 on the voice-port 0/2/0:15 to send all the incoming calls to the secrtary office, when I remove this command any one calls the company a message tells him that this number is not correct and when I put it back it rings !!
also I tried these configrations and fail
voice translation-rule 1
  rule 1 /^226492/ /2/
  exit
voice translation-profile pstn-in
  translate called 1
  exit
voice-port 0/2/0:15
  translation-profile incoming pstn-in
HI
What is the DID number you are hacing and send us debug voip ccapi inout and ISDN q931 output.
regards
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
