Difference between VG-320 and VG 320-EM
nithin louis
Hi All,
What is the difference between VG 320 and VG 320-EM.
I know VG 320 is an analog  gateway which is having 48 analog FXS voice ports with 2 numbers RJ-21 physical interfaces.
The description shows for VG 320-EM is 48-port FXS VoIP Gateway w/PVDM3-128 for Emerging Markets.
As i can see price wise VG 320 EM is almost half of the VG 320.
Searched in google ,but couldn't a good explanation.
Thanks & Regards
Nithin Louis.
Hi Nithin,
As per one of the BU guys there is no difference between the two. EM is only marketing promotion in some geographical locations.
Manish
5 Replies 5
nithin louis
Hi All,
Your comments welcome...
Nithin Louis.
Hi Nithin,
I tried finding some more info about this in our internal docs as well but did not find much. If this is really important for you then you can engage your local SE or Cisco Acct team and they should be able to assist.
Manish
Hi Manish,
Thank you very much for your comments and efforts.Sure ,I will contact Cisco local team for the same.
Nithin.
Hi Nithin,
Manish
Thanks Manish for reply.
Nithin.
