Digit Forwarding
kevin.hu
Level 3
Level 3
Hi All,
Let's say I am in Maryland, US of A.  Verizon gives me 301-811-1xxx DIDs for my office.  I have a MGCP gateway connected to the Verizon PSTN network.  This MGCP gateway is managed by my CUCM 4.3.  When my aunt calls me, does the phone company typically forward the last 4 digits or the full 10 digits?  If they forward the full 10 digits, how do I configure CUCM to trim out 301-811 before forwarding to the user DN 1xxx?
Thanks.
Chris Deren
This is a configurable parameter you need to agree on with the provider, it could ba anything, typically it is either 4 or 10 digits in US. On CUCM side you control this via Significant Digits field on the GW port configuration. So, if you only need to see last 4 digits you set this field to 4.
HTH,
Chris
Chris Deren
HTH,
Chris
Chris,
Perfect.  That's exactly what I am looking for.  Thanks!
