Disable DES-CBC3-SHA cipher CWE 326 in TMS
jeesemon.91
Dear All
      we are getting hit on below mentioned vulnerabilities in TMS application. my concern is that disabling DES-CBC3-SHA will it affect the connectivity b.w EPs & TMS ??
CWEID: 326
Vulnerability name
HTTPS connection with weak key length
Severity
Medium
Observation/ comments
Application is using DES-CBC3-SHA which is vulnerable and lesser than 128 bits. Disable DES-CBC3-SHA cipher.
Tool Used for Scanning
Qualys
Jeesemon
0 Replies 0
