Disable G722 codec - Force to use G711
Michael Murray
Level 2
Level 2
I have call recorder that only supports G711. I would like to force the phones affected to use G711 but allow all others to use G722. I know regions are based on bit rate so I don't see how to differentiate between the two. Is this possible or is it all or nothing (Enterprise Param)?
Hi Mic, there is an enterprise parameter called advertise g722. If you disable it (false) all the phones will run g711.
Additionally some phones support this setting per device such as C7945 and C7965
