disable transfer button in ip cisco phone
juan.mejia
Can some  one knows how to disable the transfer button on ip phone 7921,8851, 9971.
Regards.
But the problem is that if there is a dedicated transfer button on the device, that cannot be disabled.
java
if this helps, please rate
Mikolaj Moryto
You can modify or create new softkey template which will not have transfer button.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_01001111.pdf
Thank you,
Mikolaj
**** PLEASE RATE IF USEFUL ****
java
