Discard digits on calling number
nguyenminhtuan
Hello everyone,
I have a situation like below:
1. Incoming call
+41412456789 ---> CUBE --> CUCM ---> 6789
The number that is showing on 6789 phone needs to be 0412456789
This requirement works with below rule:
voice translation-rule 22000
rule 1 /^\+41/ /0/
voice translation-profile GRE-TP
translate calling 22000
dial-peer voice 22000 voip
translation-profile incoming GRE-TP
2. Outgoing call
Issues happen when user setup Call Forward All
+41412456789 ---> CUBE --> CUCM ---> 6789 --> CFA --> Mobile
The number that shows on mobile is +0412456789 (which is not correct).
Is it possible to fix the issue with outgoing call to show up with +41412456789 while keeping translation-profile on the dial-peer?
Louis
Deepak Rawat
Looking at your case description, incoming calls going to CM are hitting the dial-peer 22000 voip and changing the calling number +41412456789 from 0412456789. Which dial-peer is getting hit when the call is going out to PSTN and what profile have you applied on it.
Deepak
Deepak Rawat
Deepak
Hi derawat
You've pointed me to right direction.
Louis
Glad that I was able to help and thanks for marking the Correct Answer.
Deepak
